It is currently Wed Oct 18, 2017 7:07 am
 Post subject: Running rich
PostPosted: Wed Jul 23, 2014 10:01 am
Seems I'm running rich. Readjusted the timing and throttle back to stock - no change. Check engine light came on today and also back fired through the intake as well during acceleration.
 Post subject: Re: Running rich
PostPosted: Wed Jul 23, 2014 11:55 am
Correction - back fire not through intake. Pic of plugs that has been in the car for some time.
PostPosted: Wed Jul 23, 2014 4:41 pm
Pulling the code should point you in the general direction. One of biggest players is the O2 sensor. Older Metros take a while to throw a code. You can run a partially bad O2 and not throw a code.
Also, those plugs look like the guy who always shifts at 2000rpms. Not good. Bring it up to 4500-5000rpms once in awhile. Your car will thank you.
PostPosted: Thu Jul 24, 2014 1:03 pm
Showing Code 24 Speed sensor. I have swapped the tranny. The speedometer cable housing has pulled apart and the speedometer is not working. Ran across this "speed sensor is integrated into the odo/speedometer and driven by the speedo cable". So I'm thinking that's the code problem. Unfortunately I don't think that's my running rich problem as I wasn't having that code prior and the plugs have been in the car for a while. :?
PostPosted: Thu Jul 24, 2014 6:24 pm
the vss is very important to the operation of the engine. it is a primary sensor for changing the injection mode, providing injector cutoff during deceleration, and bringing idle injection on line when the car reaches minimum speed.
if the speedo cable is broken, the speedometer drum magnet doesn't cause the reed switch to operate. zero speed counts for the ecu to operate from and it will stay in some preset form of open loop operation if it doesn't see a speed pulse signal.
PostPosted: Thu Jul 24, 2014 9:02 pm
May not of explained the time line of facts coherently. Speedometer working fine before transmission swap. I damaged it during. The plugs in the pic were in the motor before the swap. Ran them with car on stands as I checked out the tranny maybe 10 minutes total. Have been running +5 degrees above stock for some time. Adjusted back to stock setting and replaced with new plugs. Changed to a 1.3 flywheel during the swap. Thinking the rich problem has been before the swap and the lighter flywheel is making it more obvious. Planning on; doing a compression check to morrow morning, find someone with a vacuum gauge, mow the yard, and swing through a salvage yard pull a speedo cable before work. :roll:
PostPosted: Mon Jul 28, 2014 9:46 am
Double checked the stock timing, fix the speedo cable and replaced the CTS - no codes :) Still running rich and backfiring :( Seems to only backfire on acceleration and under 3K :huh:
PostPosted: Mon Jul 28, 2014 1:21 pm
mine back fires on decell some times that is usually due to the motor being lean
02 bmw 330ci zhp
'98 Chevy K2500
'76 Harley Davidson FXE
