It is currently Tue Oct 17, 2017 2:40 pm
PostPosted: Sun Aug 03, 2014 10:48 pm
did some work on the cars today
lots of room
compression test on blulump of coal 150, 120, 0 removal of cylinder head was needed. found this
nice
File comment: some assembly required
:shock: :shock:
I have 3 .20 over pistons from a mk 1 engine, I will get them checked out, get new rings for them, new bearings, remove oil pump to clean it out, ball-hone cylinders and re-assemble.
did some diagnosing on the twincam, still has a dead-ish cylinder :huh:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Mon Aug 04, 2014 12:21 pm
Goodness! I bet that made a racket!
PostPosted: Mon Aug 04, 2014 11:15 pm
engine crapped out at the bottom of my driveway :( hardly made it up the driveway, found a spot to park it.
tried to move it into the shop, got the car to run enough to move it ahead, but it started rattling and would not back up into the shop :shock: I shut it down, and dragged it into the shop with the atv.
3 tech 6*gear
gti brake swap
PostPosted: Tue Aug 05, 2014 12:18 pm
buddy at the machine shop noticed right away that the broken piston had fatigue/ stress cracks where it failed. it was only a matter of time before it failed.
I hope the 3 other pistons I brought him are fine. will find out in the next few days.
3 tech 6*gear
gti brake swap
PostPosted: Mon Nov 24, 2014 4:11 pm
I got 6,000 km before failure struck again :cry:
3 tech 6*gear
gti brake swap
PostPosted: Mon Nov 24, 2014 4:57 pm
Is that the engine that continuously is detonating? I remember another posting about that car and detonation issues. I can't think of anything else other than really bad luck that would smash up the piston head like that!
PostPosted: Mon Nov 24, 2014 7:32 pm
incredibly jealous of you garage/barn!!
___________________
89 Swift gti
PostPosted: Mon Nov 24, 2014 11:25 pm
its a ok size shop for at home...I always seem to have it full of something :-P
last items I got for free were a bunch (30+) of engineered I-beam floor joists, 20,22, and 28 feet long.....going to use some of them to build a second floor (mezzanine) in my shop 8)
as for engine ping, it was minor, only at large hills or if premium wasn't used. stock cam
I installed one of mike's cams and a 6* sprocket, no engine ping noticed at all after that.
I thought I finally had a good combo, ok power, fuel economy was getting better (last tank was just over 43 mpg) not bad for a auto. did not leak or use a drop of oil.
the same day the motor failed, I do believe the trans failed as well....that morning as I turned into my work, it fought me all the way, hard to turn, it would quickly return to centre, damn near ripping the wheel out of my hands....
jacked it up, and it would not ''freewheel'' like a normal automatic....had to put it in neutral to turn the tires, and when they did spin they spun the same way, like a posi :huh: also proved true in the snow as I left work.....both front tires would spin, in drive or reverse....
was counting on the trans failing on the way home, not the motor :blackeye:
dammit the car has a new windshield, lighting, tires ,axles, brakes ,command start, underdrive, cs 130,stainless steel parts, stereo, blah blah blah.......
my wife likes the automatic. I am torn :roll: :roll:
3 tech 6*gear
gti brake swap
