It is currently Thu Jan 18, 2018 11:14 am
PostPosted: Mon Aug 04, 2014 5:44 pm
Alright well the cars a 1995 Geo metro LSI, 1.3L auto with 114K
The problem started last week on my way to work at about a 55 MPH cruise on the highway, it started "bucking" and acting like it wanted to shut off, i pulled off to a gas station and threw it in park, let it idle. After a few minutes of sitting and sputtering it finally shut off, i cycled the key to the off position then started the car back up and it ran fine. After work that day i replaced the coil thinking that was the probable cause, the car ran great all weekend and i put probably 150 miles on her. On my way to work today it started doing it again and shut off at a stop light, i started the car back up right away without turning the key to the off position and it was still sputtering so i limped off to the side of the road and let the car sit for a few minutes. It started right back up after that and made it to work and back today with no issues.
I replaced the map sensor and changed the plugs recently, other than that i keep it up to date on service.
Replaced fuel/air filters at 97K millage, along with the PCV valve
I did a quick compression test today after work just in case something was going on, everything looked good though.
For some reason i'm unable to pull any codes from this car, i pulled the cluster and replaced the check engine light bulb, but no prevail. I tried unplugging the MAP and TPS sensor to force the light on but it just won't come on, so i'm at a disadvantage there.
So can any of you guys help point me in the right direction here? I feel like whatevers going on may be fuel related
PostPosted: Thu Aug 07, 2014 6:31 pm
i have the same issue happening. 1996 metro 1.3l lsi with auto. only started when the daytime temps jumped up.tried loosening the gas cap but that didn't help. i am starting to think it might be fuel pump. just changed fuel filter 2 mos ago. car wont go 25 miles without hiccuping now that temps are in the 70-80's.
