It is currently Sat Jan 20, 2018 7:33 am
PostPosted: Sun Aug 31, 2014 7:32 pm
Hello, New to site. Greetings
I am desperate for help with help. I am assembling a 97 1.3L G13B Metro engine and purchased a crankshaft kit from Rockauto. It is a different style than the one that was originally in the engine. My crankshaft has 8 counter weights and the new one has 4. I need to find out whether or not this crankshaft will work in my engine. I really need to get this engine back in the car by Monday (Memorial day) evening and I'm sure I won't get an answer from anyone. Any information would be appreciated.
PostPosted: Sun Aug 31, 2014 8:15 pm
if it from a g13b it will work, i think it has 4 counterweight till 97 then switched to 8countrweight 97-2001, (16 valves)
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Mon Sep 01, 2014 11:40 am
Yeah looks like you maybe right. I found a listing at another crank,kit supplier that says " fully weighted" next to the crank for the 98 and up 16 valve. Can you replace the heavier crankshaft with the lighter one? Can you bolt a 8 valve head to a 16 valve short block?
PostPosted: Tue Sep 02, 2014 8:25 am
It get weirder, Its got two valve relief pistons in it. Where is the engine serial number?
