It is currently Thu Oct 19, 2017 10:22 am
PostPosted: Wed Sep 24, 2014 4:23 am
Hi everyone,
I registered over here because I'm having a problem with my girlfriends car.
I've been busy with it for months and I can't get it resolved so I'm hoping any of you are able to help me out.
It's a 98 mk2 suzuki swift 1.3 4-cyl pretty much stock. With the addition of an LPG G3 system (so it has 2 fuel systems).
The problem:
When driving (can be any speed) the system starts to lose pretty much all power (feels like no fuel or spark). If you press the clutch the engine will die.
If you stop and try to start immediately it won't start. (will crank, but won't run)
If you wait about 10 seconds it will run again. This makes it not enough time to check if there are sparks or fuel pressure.
This can happen in a normal village (50km/h) or on the highway (130km/h) or any other speed so far.
It also happens when the car is running on LPG or on petrol. So this tells me it can't be the fuel pump (LPG has none) it isn't the injector as the LPG has it's own.
It happens on occasion, for example you can drive 200km without any problem, but you can also drive 5 with it happening twice.
The car also doesn't show a CEL when it happens.
What I did to resolve it:
Check for error codes (using the short in the diagnostic connector under the hood). This only showed 12 which should be good.
Change spark plugs
Change distributor cap
Change distributor rotor
Change high tension leads
Check if the EGR is dirty, it wasn't any more than normal, but cleaned it any way as it was now out of the car
Changed exhaust system as the CAT was in a bad shape also there was a hole in the rear silencer. And I could get it for really cheap.
Remarks:
Even though the car is registered to be from 98, i don't believe it's a 98 model, I think it's a few years earlier.
For example, it does have an obd2 port, but only the DLC protocol is available on this port (which unfortunately my scanner doesn't understand).
It doesn't have the diagnostic in the fuse box
It only has the diagnostic connector on the firewall
PostPosted: Thu Oct 09, 2014 6:02 am
Nobody has any tips?
PostPosted: Thu Oct 09, 2014 12:54 pm
hey mate,
it sounds like you have a electrical fault in your ignition system.
check you dizzy internals for fauls, and check coil.
hope this helps. :)
PostPosted: Thu Oct 09, 2014 5:33 pm
electrical problem are very common for this year of car
there is a small fuze block located next to your battery unbolt it and check the main lead for corrosion
also the fuze box inside your car remove it and inspect it for burnt are arcing within the block it is like a sandwich
and has layers stack on each other (4) also check all conectors going to this fuze block for corrosion and Arcing..jv&s
I will try to find a picture
PostPosted: Thu Oct 09, 2014 5:37 pm
see black spots.?
Not good
PostPosted: Thu Oct 09, 2014 8:16 pm
Nice board. Bet that took a long time to find.
PostPosted: Mon Oct 20, 2014 6:28 am
Sorry for the late reply, I was on a holliday.
Everybody thanks for the replies!
I'll check the fuse boxes as soon as I get the chance and I'll update this post with what I find.
