It is currently Sat Feb 24, 2018 2:20 am
 Post subject: can u turbo a non turbo?
PostPosted: Fri Oct 24, 2014 2:18 pm
im thinking this has been asked loads and I know in theory its possible running a low boost system but will the ECU adapt?? mine is a 97 (built in 96) Pontiac fire fly 3 cylinder gas.
was thinking 5-7psi system with a small intercooler.
the engine is strong with no leaks and does not burn oil.
thanks stuart
PostPosted: Fri Oct 24, 2014 5:17 pm
With a few minor mods, it's not a problem. The motors are very well built, and can stand that small amount of boost easily. Search for coolant temp sensor mod
PostPosted: Sat Oct 25, 2014 10:28 pm
Here ya go. I had in my Favorites. viewtopic.php?f=2&t=26951&hilit=coolant+sensor+mod&start=0
Ken...........
PostPosted: Wed Oct 29, 2014 11:41 am
right then as budget is every thing I will start looking for a nice small snail to give my mighty three cylinders a helping hand :) then fab up a manifold and braze a oil return to the sump and then look for some where to tap into the oil feed needed to keep the snail lubed up. now I understand carbs and mechanical stuff but electronics baffle me so will prob be asking questions later on as I get easily confused lol
thanks people :)
