It is currently Tue Oct 17, 2017 12:11 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Nov 25, 2015 9:07 am
hi guy's and girl's,
this is the cylinder head I'm going to be using for the turbo motor.
PostPosted: Fri Nov 27, 2015 7:33 am
I've finished off the flat floor cover that I made from a old roller bind.
and the extra 3 gauges for the dash.
PostPosted: Fri Dec 04, 2015 3:53 am
hello guy's and girl's
I received my hub centric rings and fitted some service parts.
still waiting on parts from ebay :)
PostPosted: Thu Dec 10, 2015 1:54 am
hello guy's and girl's,
still preparing to replace the motor and box, but doing some swaps from my old car
to this one.
the coolant is why it's getting a motor swap.
the old motor/ new turbo motor, when done.
I'll keep you posted :yeahyeah
PostPosted: Thu Dec 10, 2015 6:55 pm
Good work I love the clock.
PostPosted: Sat Dec 12, 2015 6:44 am
hello again guy's and girl's,
thx RP91gt
this is the motor that is going to be going in until I build the turbo motor.
PostPosted: Tue Dec 22, 2015 5:23 am
Hello guy's and girl's,
The front end suspension rebuild is done, but
I'm wait on some seals before doing the motor swap.
PostPosted: Mon Dec 28, 2015 1:49 am
hello guy' and girl's,
today was the day for the motor swap :)
went well just need to finish off ac and a few things before it's on the road :yeahyeah
PostPosted: Sat Jan 02, 2016 4:14 am
I decided to add a Usb port to the dash surround.
I used a cigarette lighter socket and a adaptor for usb power.
I still have to install it back in the car and wire it :)
PostPosted: Thu Jan 14, 2016 12:47 pm
Hello Guy's and Girl's,
this is a flow up.
this hole was widened to fit the usb cable.
this is the start of the turbo motor.
PostPosted: Sat Jan 30, 2016 7:10 am
I have now got the last of my parts or a new project, I'm not sure yet.
It has a few problems.
PostPosted: Sun Feb 07, 2016 2:58 am
I've decided to restore the Gti to it's former glory.
I'll keep you posted.
PostPosted: Tue Feb 16, 2016 1:44 am
I've started to work on a front lip, it's a upper front bumper.
still need a lot of work but it's a start :)
PostPosted: Sat Feb 20, 2016 6:59 am
I have been working on the front bumper, first was to fill in the gap with foam.
then to put some fiberglass over the top.
i'll keep you posted :yeahyeah
PostPosted: Tue Feb 23, 2016 4:11 am
this was the 2nd step of fiberglass work, next is to shape and final glassing.
PostPosted: Thu Mar 03, 2016 9:16 am
I have been waiting for the fiberglass to fully set before sanding it into shape.
and I have started to fill in the low spots with a bit of bog.
and the process continues, a lot more to go yet.
:yeahyeah
PostPosted: Sun Mar 06, 2016 12:16 am
Looking good man.
Vogtland lowering coils
Ngk plugs
8mm silicon wires.
PostPosted: Sun Mar 06, 2016 12:21 am
Are you going to upgrade the carburetor?
Ngk plugs
8mm silicon wires.
PostPosted: Mon Mar 07, 2016 1:02 am
hey guy's and girl's,
I don't plain to upgrade the carby at this stage but I do intend to upgrade to efi still.
thanks BikeAmusPrime
PostPosted: Sat Mar 12, 2016 2:20 am
this is the progress I have made :)
Here is a couple of photos I have for the 8v cylinder head.
Inlet port
exhaust port
the straw is in a coolant passage near the exhaust port.
I hope this helps :)
PostPosted: Wed Mar 23, 2016 11:14 am
Hi guy's and girl's,
Just a quick update still working on my front bumper.
A old friend finished my lower front brace.
PostPosted: Wed Mar 30, 2016 4:51 pm
Iv'e been following this with interest, keep it up and thanks for the photo's :D
PostPosted: Mon Apr 11, 2016 4:15 pm
The bumper is back on the car for final steps.
hey thank Zammo :)
PostPosted: Sun Aug 07, 2016 2:26 am
hello guys and gilrs,
the front bumper has had it's final shaping, and now it's time for body work and paint.
the motor is coming alone in it's mockup stage.
PostPosted: Fri Oct 21, 2016 11:49 am
Hello boys and girls,
I had the cylinder head sent out for a stock rebuild.
It's taken awhile but i have finished building my ecu, this is the cheapest form of ecu i've seen.
I've started the body work.
