It is currently Tue Oct 17, 2017 6:42 pm
 Post subject: Timing help
PostPosted: Wed Feb 18, 2015 10:37 am
Hello, I've done a couple of timing belts before following the forum here.
But usually I just park the car, take off the old belt and don't move anything..so no timing changes are made. But now the car won't fire..has compression gas and spark..I'm pretty sure the belt jumped.so now I need to put a new belt on, but how do I know the pulleys are in the right place please.
Just for the record, I used to follow a sticky on here reminding me how to do it, it was the best.it had pictures and step by step instructions.
But the laptop died now I'm on my tablet and I lost my bookmarked history and can't find it.
Many thanks Roy
 Post subject: Re: Timing help
PostPosted: Wed Feb 18, 2015 2:39 pm
This may help...
gallery/image_page.php?album_id=870&image_id=17932#
Pull the distributer cap and make sure the rotor is aligned with the #1 plug wire on the cap.
PostPosted: Wed Feb 18, 2015 8:44 pm
I cannot thank you enough, that was exactly what I was looking for..I went straight outside and realized the belt was not tight enough and had jumped a couple of teeth.
I put it back how it was in that picture and quickly turned it over with no pulleys or other belts and it idled perfectly immediately.
Thankyou very much
PostPosted: Wed Feb 18, 2015 9:59 pm
Wish I had thought of that to confirm 100% I got my timing belt right, but I suspect I did anyhow.
PostPosted: Thu Feb 19, 2015 2:06 am
Somewhere on this forum is a really good step by step easily understandable guide, with pictures timing belt change tutorial, but I could. It find it...
I tried searching and found someone w ho found it
This. Is what my search re turned
search.php?keywords=Timing+belt.+Howto&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Here's where you can find the timing belt howto:
Problems & Fixes
Title: "Timing belt replacement 1.0 Mk3 Howto?"
written on date: July 22, 2005
This evergreen should be made sticky.
regards, Helmut
