It is currently Wed Oct 18, 2017 7:23 pm
PostPosted: Sat Oct 17, 2015 12:14 pm
Are the G10 crank position sensor and the cam position sensor Hall type or VR (variable reluctors/mag)?
1971 Honda N600 Transplant
w/ Suzuki G10 engine
and 5 speed trans
PostPosted: Sat Oct 17, 2015 3:59 pm
you don't give the year of your car but the g10 controls are all variable reluctance type sensors. the crank sensor reads a 6 point star wheel on the crank's lower timing wheel and the distributor mounted sensor reads 3 fingers on the distributor shaft.
that would be on the 95+ and up g10 engines. 94 and back didn't have crank sensors.
PostPosted: Sun Oct 18, 2015 9:16 am
t3 ragtop
That is exactly what I needed to know. This is a project motor that is still to be purchased. Now I know that I will need to build or buy conditioning circuitry to use an after market ECU. Or dump it all and go to trigger wheel and cam sensor like I did with the EFI I put on the original N600 engine.
My car is a 1971 Honda N600 that presently has a 1994 G10 motor and trans shoe horned into it.
Thanks
David
and 5 speed trans
