It is currently Thu Oct 19, 2017 6:52 am
PostPosted: Thu Nov 30, 2006 9:48 am
These are pics of the 1992 Geo Metro factory service manual and the Geo service supplement.
Driveability And Emissions 1.0L (VIN 6) 6E2-A-2 component locations
click for full image
Driveability And Emissions 1.0L (VIN 6) 6E2-A-3 ECU wiring diagram 1/2
Driveability And Emissions 1.0L (VIN 6) 6E2-A-4 ECU wiring diagram 2/2
Driveability And Emissions 1.0L (VIN 6) 6E2-A-5 ECU pinout
Driveability And Emissions 1.0L (VIN 6) 6E2-A-6 diagnostic codes
Driveability And Emissions 1.0L (VIN 6) 6E2-C2-14 TPS check and adjustment
Driveability And Emissions 1.0L (VIN 6) 6E2-C2-15 TPS check and adjustment con't
Driveability And Emissions - Fuel Injection 6E-5 Intermittent "Check Engine" Light, Reading Codes
Driveability And Emissions - Fuel Injection 6E-6 Reading Codes con't
Driveability And Emissions 1.0L (VIN 6) 6E2-C-01 Section C Component Systems
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-01 Section C1 Engine Control Module And Sensors (Contents, General Description)
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-02 Self-Diagnostis Function, Fail-Safe Function
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-03 Oxygen Sensor - Standard Emissions
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-04 Engine Coolant Temperature Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-05 Throttle Position Sensor, Intake Air Temperature Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-06 Vehicle Speed Sensor, Manifold Absolute Pressure Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-07 Camshaft Position Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-08 Diagnosis, Diagnosis Precautions, Diagnostic Request Terminal
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-09 Test Switch Terminal, On-Vehicle Service - Engine Control Module
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-10 On-Vehicle Service - Engine Control Module con't, Oxygen Sensor, Engine Coolant Temperature Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-11 On-Vehicle Service - Engine Coolant Temperature Sensor con't, Throttle Position Sensor (standard emissions)
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-12 On-Vehicle Service - Throttle Position Sensor con't
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-13 On-Vehicle Service - Throttle Position Sensor con't
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-14 On-Vehicle Service - Throttle Position Sensor con't
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-15 On-Vehicle Service - Throttle Position Sensor con't, Intake Air Temperature Sensor
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-16 On-Vehicle Service - Manifold Absolute Pressure Sensor, Diode Module
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-17 On-Vehicle Service - Specifications
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-18 Chart C-1A - Electrical Load Idle-Up Signal Check
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-19 Chart C-1A - Electrical Load Idle-Up Signal Check con't
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-20 Chart C-1B - A/C Idle-Up Circuit Check
Driveability And Emissions 1.0L (VIN 6) 6E2-C1-21 Chart C-1B - A/C Idle-Up Circuit Check con't
PostPosted: Thu Nov 30, 2006 11:29 am
abby normal
Thanks, Lihtan :worship:
PostPosted: Thu Nov 30, 2006 7:30 pm
nice post :) thanks
PostPosted: Fri Dec 01, 2006 2:35 pm
ditto
PostPosted: Mon Jan 07, 2008 10:03 pm
I don't know, I seem to get 403 error for the pictures?
Is that just me? :S
PostPosted: Mon Jan 07, 2008 10:21 pm
Sorry seemed to be firefox, IE works perfect. Thanks for the pics, very much appreciated!
PostPosted: Tue Aug 26, 2008 12:50 am
BIG help, thanks for the pics, very usefull
nothing sweetest than fits everywhere at 65 mph!
PostPosted: Tue Aug 26, 2008 8:33 am
just to let 'you people' know, i have the 2000 geo metro service manual and can get pics of certain things that ppl want.
PostPosted: Sat Sep 06, 2008 10:36 pm
Clicky no worky :( Gotta copy and paste.
Project Page
Image Image
PostPosted: Sat Nov 15, 2008 9:41 pm
Thanks dude. :)
94 1.0L Manual TBI Canook
PostPosted: Tue Feb 10, 2009 5:48 am
Lithan
İs it carbureted engine 1.0 ,and same is 1991 ?
correct?
PostPosted: Sun Apr 26, 2009 7:23 pm
from my 1992 Metro Service Manual - some specs that I had desired to know but never could get any firm information on. Let me know if there's any more information/pics desired...
-Engine General Information & Mechanical Diagnosis (6-8)
http://www.iqmetals.com/else/Metspec1.jpg
-Engine Mechanical-1.0 Liter L3 Vin Code 6 (6A1-20)
http://www.iqmetals.com/else/Metspec2.jpg
-Engine Mechanical-1.0 Liter L3 Vin Code 6 (6A1-62, 63, 64)
http://www.iqmetals.com/else/Metspec3.jpg
http://www.iqmetals.com/else/Metspec4.jpg
http://www.iqmetals.com/else/Metspec5.jpg
-Cooling & Radiator (6B-16)
http://www.iqmetals.com/else/Metspec6.jpg
Davis M.
Victor, MT - western edge of the sizable state
PostPosted: Sun Dec 13, 2009 4:26 pm
is anyone can send real picture,regarding assembly thorttle cable-thorttle body connection ,ı will check my car connection ı suspect something isnt right .
if anyone cannot send please send technical pages regarding this subject.
Thank you
PostPosted: Tue Mar 02, 2010 11:20 pm
Here :http://swift.hit.bg are 500MB valuable information, schematics, manuals etc. for swift/metro.
https://sites.google.com/site/suzukiswiftinfo/
PostPosted: Tue Jan 31, 2012 11:41 pm
Any one have the specs for the flywheel step height? My buddy has a machine shop and said he could machine the flywheel but needs to know the step height so he can cut the pressure plate mounting surface after he machines the friction surface to get the proper preload on the friction disk.
PostPosted: Wed May 04, 2016 4:10 am
สล็อต
About three years to late with your response, normally yes that would probably work but is not the correct answer as you have to take into consideration normal wear of the friction surface and if the previous owner got in there with a disk sander to de-glaze the friction surface when doing the previous clutch job, being that the wear on the clutch was relatively minimal and the was quite a bit of clutch chatter and slippage under load i would suspect that was the issue hence why I asked the question. the solution why pee around just replace the flywheel if nobody can offer the correct answer...
PostPosted: Thu May 05, 2016 3:47 am
Does anyone have a wiring diagram in map version like T3 and Gti one? I would need to track where it goes.
Thanks.
