http://www.teamswift.net/
How restrictive is stock intake ?
http://www.teamswift.net/viewtopic.php?f=5&t=62771
Page 1 of 1
Author:  c4boom [ Wed Jun 14, 2017 7:13 pm ]
Post subject:  How restrictive is stock intake ?
Was thinking of porting it and cutting the plenum floor to open it up. Is it worth it.
Author:  1992Poddy [ Sat Jul 29, 2017 12:51 pm ]
Post subject:  Re: How restrictive is stock intake ?
I'm not sure how restrictive the factory intake is but you can hook up a pipe to the edge of the intake plenum with a cone filter on the end eliminating the factory filter. I'm not sure if its possible to fit a larger throttle body on the car but if it is then you can try that as well.
Author:  Kranky99 [ Wed Aug 30, 2017 7:24 pm ]
I cut out the bulk of the housing, just enough plastic left to keep the filter clamped in. Seems to increase flow with both the stock filter and the K&N I have.
Edit: it should also be noted I guess that I have a bigger throttle body (45mm) as well, that changed the sound of the car for the better and really made a noticeable difference in power surprisingly.
http://www.phpbb.com/
