It is currently Thu Oct 19, 2017 3:52 pm
 Post subject: g16a need help
PostPosted: Fri Jan 06, 2006 2:41 pm
hi im new hear and am looking to turbo my g16a baleno. and want to know what is the compression ratio on these standard and what sort of boost could i run safely as i just want a bit more poke out of it but be able to still use it daily. doing the work myself is no prob as i have just finished a turbo project over my work. we turned a bmw 325i motorsport into a 2.7 lower comp T3 monster only runing at 8psi at the moment because on the electronic side we have only used bigger injectors,3bar fuel regaulator and a retard box. the owner is now saving up to have a complete managment system made. we are expecting around the 450 hp mark, on a lsd that will be a good grin to drive! but back to the reason im hear anyhelp would be very helpfull. thanks ian
p.s you will have to bear with me as i am machanicly minded im not into all this writing stuff.ian
PostPosted: Fri Jan 06, 2006 9:13 pm
the compression ratio on the G16A is 1:9.8 according to their website:
http://translate.google.com/translate?u ... uage_tools
PostPosted: Fri Jan 06, 2006 11:00 pm
The mad quebecer
The mad quebecer
16v: 9.5:1
8v: 8.9:1
PostPosted: Sat Jan 07, 2006 5:22 am
ok thanks any1 got ideas on what sort of boost these lumps can take?
thanks ian
PostPosted: Sun Jan 08, 2006 3:20 am
you could run about 7psi safely, that's with the stock bottom end, even going up to 10psi could be risky with a stock block.
PostPosted: Sun Jan 22, 2006 1:48 pm
I'd say 10psi all day if you lower the compression just a bit.
