It is currently Fri Feb 23, 2018 1:42 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
PostPosted: Mon Jun 19, 2006 12:07 pm
It is an approximate calculation.
Here we go:
I assume the valve cut-outs to have the same volume for std G13B piston and Vitara ones. This is not true, the vitara's are larger, but let's keep things simple. Their difference is not significant in the final result. It even might be compensated by the cutout/dish overlap.
1-Stock G13B chamber volume:
CR = 10 = ( Cyl volume + Vc)/Vc
10 x Vc = 324.7 + Vc
(10 x Vc) - Vc = 324.7
9 x Vc = 324.7
Vc = 324.7 / 9 = 36.077 cc = G13B CHAMBER VOLUME
When fitting the deeper 71C50/51 piston, there is more chamber volume, because a)compression height is lower ... b) the dish.
2-Volume added by the lower compression height:
Stock compression height: 29.1mm
71C50/51 compression height: 28.4mm
Difference : 29.1-28.4 = 0.7mm = 0.07cm
Radius of piston = 75mm/2 = 37.5mm = 3.75cm
Volume = Area of piston x difference in compression height
Volume = PI x (3.75) ^ 2 x 0.07
Volume = 3.1416 x 14.062 x 0.07 = 3,09 cc
3-Volume added by dish:
The dish is 6mm deep with truncated cone shape. (. The larger diameter is 58mm and the smaller one is 45mm)
R=58/2 = 29mm = 2.9cm
r =45/2 = 22.5mm = 2.25cm
h=6mm = 0.6cm
V=h x PI/3 x (R^2 + Rxr + r^2) this is the volume of a truncated cone.
V= 12.56 cc
4-New chamber volume
So, the new chamber has:
NCV = Stock Volume + Dish volume + Top volume (compression height)
NCV = 36.07cc + 12.56cc + 3.09cc = 51.72cc
5-New cylinder volume:
The piston has now 75mm diameter, so, the new volume is:
r= 75mm/2 = 37.5mm = 3.75cm
h= stroke = 75.5mm = 7.55cm
Cyl vol = PI x (3.75^2) x 7.55 = 333.55 cc
6- New compression ratio:
CR = (Cyl vol + NCV)/(NCV) = 7.44
If we consider the valve cut-outs and , which are a bit larger for the vitara pistons, The CR gets slightly lower, around 7.3 for a 1cc difference in valve cut-outs, but it's still an assumption. So, CR is around 7.3~7.5
For the other pistons, with smaller dish, doing the same calculation, CR is 7.7~7.9
Deshrouding the valves and polishing the chamber leads to even lower CR depending on the job.
PostPosted: Tue Jun 20, 2006 2:30 am
Thank you very much for the calculations Caaarlo, I understand a lot better now.
Have you made your final decision on choice of pistons yet then? and are you considering skiming the block and head to higher the compression ratio slightly?
These are the ones I put into my engine...
http://www.turboproject.pwp.blueyonder. ... coated.jpg
Phil
PostPosted: Tue Jun 20, 2006 8:23 am
Well, 7 is quite low for the boost level I intend to use (below 15psi). I don't know yet. If I can get the other ones with smaller dish, then I will install those to have at least 7.7. Otherwise, I will probably stay with stock compression and lower boost.
Another option would be to install G13BB pistons for Suzuki Jimny which lower the CR to around 9 on a stock head and maybe mid eights for a worked chamber. I am talking about this piston (left):
So far, theoretical and approximate CRs with stock G13B head would be
G13BB = ~8.8
Vitara 4mm = 7.9~7.7
Vitara 6mm = 7.5~7.3
Could someone please measure these values on an actual engine ?
PostPosted: Tue Jun 20, 2006 9:11 pm
I don't think you would dip below 8:1 compression ratio with either set of Vitaras. From my understanding, with a completely stock head, it's more like 8.5:1.
93' Suzuki Swift Gt Turbo
PostPosted: Tue Jun 20, 2006 9:58 pm
Yes, I wanted to dismitify the legend. Everybody thinks it is 8.5, but nobody actually measured it, or the ones who did it, haven't posted their results. Even me, I bought the pistons thinking they were around 8.5 because everyone was repeating "Vitaras lower CR to 8.5" in unison. But once I had them here... surprise !!!
I have found some posts where people is surprised to get around 7 CR with vitaras, and they ask themselves where did they screw up, thinking they should get 8.5.
PostPosted: Tue Jun 20, 2006 10:24 pm
The mad quebecer
The mad quebecer
The eight of the pistons acount for the lower compression ratio you're getting Caarlo. I noticed some pistons manufacturer aren't paying much attention about how close their parts are to the OEM ones. I've seen similar things hapenning to the DSM guys. You should get a set of OEM pistons and see how they compare.
PostPosted: Tue Jun 20, 2006 10:30 pm
I have made the calculations according to piston specifications found in several manufacturers like TOTO (japanese, probably the manufacturer of OEM pistons), JCC, YCP, CKT, ARCO and TIK (all have the same, maybe 0.1mm difference in compression height), and not my actual piston dimensions.
Measured the piston with a caliper, and they are quite accurate compared to the specifications. Compression height, dish depth, piston lengh, diameter, they are ok. So, If I wanted to calculate the actual CR for my pistons, the numbers should be pretty close.
I have returned the pistons, and requested some G13BB ones if available.
PostPosted: Tue Jun 20, 2006 11:08 pm
here here, i second this move ... i too would really love to know what CR i'm running...
From reading teamswift forums i was made to believe that vitara pistons on a stock head would be about 8.5-9.0:1 CR
if its really 7.6:1 well that would be something ...time to bump my timing further !!!
Keep it real
GTi Turbo [Microtech LT-8 Stand Alone ECU]
17psi Water Injected
203whp & 182 torque
PostPosted: Tue Jun 20, 2006 11:11 pm
This is a big jump in CR from 8.5-9.0:1 to 7.6:1 don't ya think ....
the ones that caaarlo had the "6mm dish" are the same ones i got my my suzuki dealers, and those are SGP !!!
Keep it real
203whp & 182 torque
PostPosted: Tue Jun 27, 2006 9:39 am
But does it matter that the cr is less then what was excpected? I mean look at all the guys using these pistons with good results in there turbo projects.
If it works then why not use it?
Ryan
PostPosted: Tue Jun 27, 2006 10:30 am
Ryan
off boost performance ...
even thou i don't have a problem i just adjust timing , but you can go so far with timing and now more.
also efficiency is another prob
Keep it real
203whp & 182 torque
PostPosted: Thu Jun 29, 2006 1:34 am
i'm not much of a genius but listen to this............
lets say a stock gti has 210psi cylinder pressure along with the fact that we all know that the compression ratio is 10:1.
could we then say........... 210/10 = 21 ------- call this alpha
then lets say the new cylinder psi = 170psi....... with the low compression pistons after installation.
we could then say that 170/21 (alpha) = 8.1.......... which would be the new compression ratio.
i mean this eliminates a lot of confusion and accomodates all the variations in piston height, dish, chamber volume, groove depth etc....
PostPosted: Thu Jun 29, 2006 6:10 am
i think there is a difference between static compresion ratio ans what yours on about badboyscyari. :?:
PostPosted: Thu Jun 29, 2006 8:40 am
Yes, one thing is Compression, and another thing is Compression Ratio.
Anyway, did you get those values on the smaller dish pistons or the deeper ones ?
PostPosted: Thu Jun 29, 2006 8:42 am
ian is that 170psi from the pistons caarlo posted above?
I think i'll try and get the compression test from my car today and post it ...
Keep it real
203whp & 182 torque
PostPosted: Thu Jun 29, 2006 9:54 am
i have seen this done on a honda before
jus the same.......... one of my friends bought pistons for his honda that were to raise his compression to 12.5:1 from 11:1 and we did the same static compression test and the maths i did worked out right.........
to me (my opinion) if you have a higher compression ratio, u must have a linear increase in static compression because they are both related to the same cylinder. makes sense to me and numbers dont lie.
is as if you finding the area and volume of a cup of water..... more surface area = more volume, in one way or another
PostPosted: Thu Jun 29, 2006 10:38 am
Ok sounds good but was the 170 from a swift with the low compression pistons?
Keep it real
203whp & 182 torque
PostPosted: Thu Jun 29, 2006 11:16 am
Absolutely right. Number don't lie... only if you take everything into account. As far as I know, compression is not linearly related to compression ratio.
Either way, what kind of pistons do you have ?? because I have calculated one piston to have around 7.4 and the other one to have around 7.9. Which is pretty close to my calculations. Did you shave your head or something ? Maybe this explains why you're having such a good compression while most people is getting ~150 psi from the deep dish vitara pistons.
PostPosted: Fri Jun 30, 2006 6:39 am
I was getting 165 - 170psi compression with the deeper dish pistons, but the block looked like it had been skimmed quite a bit in its life compared to another block I have.
Phil
PostPosted: Mon Jul 03, 2006 4:54 pm
7.4:1 is absolutely perfect for a turbo engine, run 30psi boost and shut the hell up :razz:
PostPosted: Wed Jan 28, 2009 8:19 pm
These are some interesting calculations, I just bought myself a set of 75,5mm Deep Dish Vitaras. The motor is going to be machined soon and ill measure when its assembled in the negine the actually findings.
PostPosted: Fri Apr 10, 2009 1:05 pm
Ricardo, can you post your findings ? Did you measure the actual compression ratio ?
PostPosted: Sat Apr 11, 2009 11:13 pm
please! :wink:
Bong,Bong,Bong....zuki's
PostPosted: Mon Apr 13, 2009 2:50 am
i just done a compression test the other day on a different motor[2.0] which was just rebuild and this is with supposedly 8.3-1 compression ratio and we got 125psi however it hadent even ben started yet so runing in will make a difference and that was cold and dry
steve
N/A THE EXPENSIVE WAY TO GO SLOW
www.uk-ssgti.com
PostPosted: Tue Apr 14, 2009 6:29 pm
steve
Well, but this has nothing to do with a 1.3 + Vitara pistons. Furthermore, cylinder compression depends on the cam profile and health of the engine internals. Therefore Compression Ratio is a more descriptive parameter than cylinder compression.
