It is currently Wed Feb 21, 2018 12:01 pm
 Post subject: IhI rhb52 turbo a/r
PostPosted: Tue Jan 30, 2007 2:18 pm
I have a question regarding the ihi rhb52 turbo tat I want to use. The turbo is off of my ford turbocoupe it is the largest compressor wheel equipped rhb5 turbo that I can find. I am also aware that these turbos came in many different automobiles. I am not worried about using the compressor as I am about the a/r of the turbine. I want this to spool similar to a t23 .48 .42. My turbo is in good shape. I want to run to 16psi on the motor which has been fully rebuilt and has vitara pistons. My question is what turbocharger out of another rhb5 equipped vehicle can I pirate the turbine housing out of, so that I can hybrid this turbo to spool sooner, that is if you guys think that I should even bother. I was considering a subaru or probe or impulse rs housing could you please tell me what will work
PostPosted: Tue Jan 30, 2007 2:43 pm
Any one of those should do the trick.
You'll probably find the smallest exh. housing on a I Mark 1.5 8V turbo.
PostPosted: Tue Jan 30, 2007 5:23 pm
Bozo the crying clown
the maserati biturbo's have a 0.47 (12) exhaust housing.
Matt
Megasquirt Specialist.
www.mtmotorsport.ca
PostPosted: Thu Feb 08, 2007 2:18 am
#1 in locked posts
I also have a Turbocoupe (IHI equiped). If I remember the IHI had an exhaust A/R of .58 and the T3 models got the .63 A/R.
The RHF5 is the closest map to the stock RHB5 of the Turbocoupe.
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
John
PostPosted: Thu Feb 08, 2007 10:33 am
If I recall, the numbers are cast into the housings, but are metric.
 Post subject: Re: IhI rhb52 turbo a/r
PostPosted: Mon Jul 26, 2010 3:52 am
I have this turbo size matched for the G13B
\m/
PostPosted: Mon Jul 26, 2010 9:19 pm
The T-coupe T3 is .60/.63, might spool around 4000 if ya bolted two G10's together!
Scott
Its not lag, its suspense...
1987 mk1 T3
