It is currently Sat Oct 21, 2017 12:03 pm
PostPosted: Tue Feb 27, 2007 1:00 am
low boost is 8psi and high is 18psi on the subaru wrx td04L turbo. does anyone have any experiences with this turbo or the sti turbos?
i have been running this setup for 4 months now and the only problem i have is overheating sometimes, need help with that too.
PostPosted: Tue Feb 27, 2007 7:45 am
The mad quebecer
The mad quebecer
You need to be more specific about your setup. What fuel management are you running? Octane rating? intercooler size? exhaust size? What injectors are you using? Stock head & cams? Compression ratio?
The TD04L is kinda small for hi boost application but you should still show healtier figures with this turbo. At least you do't need 18 PSI to get 196hp, that's for sure. I smell poor tuning here. Show us a few pictures of the setup if you can also.
PostPosted: Wed Feb 28, 2007 12:26 am
i'm running a GReddy emanage ultimate, 90 octane, FMIC 22"x6"x2.5", exhaust 2"-2.5", 380cc injectors, stock head and cams, thick head gasket for lower compression. engine fully rebuild one year ago.
PostPosted: Wed Feb 28, 2007 12:42 am
if thats the power produced with a cooler 18psi, I would like to see your afr's, getting bad mileage?
PostPosted: Wed Feb 28, 2007 9:51 am
actually, what throttle body are you running
PostPosted: Thu Mar 01, 2007 1:35 am
i'm running the stock throttle body with 11.0:1 afr in boost and i get really good gas mileage off boost.
PostPosted: Thu Mar 01, 2007 3:21 am
I would of thought you could lean the A/F ratio safely to 11.5:1 without any problems. Some people tune to 12:1 in boost for more power.
Phil
PostPosted: Sat Mar 03, 2007 11:03 am
i know ppl go to even 12:1 AFR but my car has been running for the past 3 years with 11:1AFR and it has never even smoked or given an engine problem. the only thing happened to me was that i had broken the exhaust camshaft last week.
besides that, this engine has only been pulled to change a blown head gasket.
PostPosted: Sat Mar 03, 2007 11:09 am
my clutch is slipping though, forgot to add that. i damaged the gearbox seal and the gear oil came unto the clutch. this was b4 the dyno. i fixed the gearbox but nevr cleaned up the clutch, i ran out off time. but since then on high boost at about 4-5k rpm the clutch slips. i first noticed it on the dyno but i thought the wheels were skidding off the dyno. it was after going back unto the road i realised it was the clutch.
PostPosted: Mon Mar 05, 2007 1:12 am
sweet lookin solid cams.... happy my two 1990 engines have hollows.
Project Metro
~Possibly For Sale~
PostPosted: Thu Mar 08, 2007 11:17 pm
impressive works like these are inspiration to alot of us. on this side of the table ull get praises for your accomplishments, lol. yeah, can we see pics?
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Sun Mar 11, 2007 2:03 pm
lol claude b thats swiffy, lol
PostPosted: Sun Mar 11, 2007 9:53 pm
how is the e manage working out ?
PostPosted: Mon Mar 12, 2007 10:26 pm
i still haven't got the wires sorted that we spoke about. the car doesn't start when i hook the wires up like in the diagram. i think its the injectors, i have low impedance.
i meant to ask you jgw, are you running low impedance injectors or high impedance?
PostPosted: Wed Mar 14, 2007 9:54 pm
yeah, i know who it is, the pics are also on wheels, jus neva waan bait up di ting, u si mi. jus keepin it kool, u si mi. gwaan thru ute. mek wi si some pics.
PostPosted: Sat Mar 17, 2007 2:38 am
high, 525 precision injectors
