It is currently Fri Oct 20, 2017 8:36 am
 Post subject: RHB31
PostPosted: Thu Mar 01, 2007 10:15 pm
Hello I have some questions about this small turbo RHB31. I'm in the process of installing this turbo on a 680cc ATV. First question is the turbo to small? I've had 2 people say its to small and about 10 or more saying it will work. I have most everything fabbed up and hope to have it running this weekend if all goes well. Another question is the turbo is water cooled can I just block off the water ports or do I need to keep it water cooled? Here are some pics of what I've done so far. http://rides.webshots.com/album/557217476VTOQtt
 Post subject: Re: RHB31
PostPosted: Fri Mar 02, 2007 12:12 am
rhb31 hmmm. small for a car but id say run it. if not that an rhb5 off a probe or something. what type of fuel system are you going to run? one more thing do you have a turbo 420a eclipse???????
people are stupid
PostPosted: Fri Mar 02, 2007 12:13 am
Main twit
that turbo will be aok for that application.... if im not mistaken, artic cat uses a 660cc suzuki motor with about that size turbo...
u can leave the coolant lines empty if you wish... it will prolong the life of the turbo if you do use the coolant though...
Tim
MT Motorsport
www.mtmotorsport.ca
PostPosted: Fri Mar 02, 2007 2:07 am
Arctic Cat uses Suzuki motor in all their sleds. The 660 turbo triple is the same motor that is in the Suzuki Wagon R.
PostPosted: Sat Mar 03, 2007 9:48 pm
I worked on my project some more today. Here some updated pics http://rides.webshots.com/album/557217476VTOQtt
PostPosted: Tue Mar 06, 2007 8:04 pm
I got my project running today and still have a few bugs to work out. I have a question about boost. Looks like I'm only making around 5psi of boost shouldn't I be making more?
PostPosted: Tue Mar 06, 2007 10:07 pm
Bozo the crying clown
what is the wastegate set to? (check with low pressure regulator) it could be set to around 5psi
Matt
Megasquirt Specialist.
www.mtmotorsport.ca
PostPosted: Thu May 03, 2012 10:20 pm
How did you route your oil lines?
