It is currently Tue Feb 20, 2018 3:05 am
 Post subject: low boost turbo
PostPosted: Sun Jan 20, 2002 9:41 pm
Hi guys, I would like to know what I need to turbocharge my swift. I have a brand new GT motor and I think I only need turbo, manifold, boost controller and some hoses to run at 5-7psi. Any comment or suggestion?I'll add an intercooler if its too hot under the hood... <p></p><i></i>
 Post subject: Re: low boost turbo
PostPosted: Mon Jan 21, 2002 5:29 am
<!--EZCODE QUOTE START--><blockquote><b><i>Quote:</i></b><hr> "I think I only need turbo, manifold, boost controller and some hoses to run at 5-7psi."<hr></blockquote><!--EZCODE QUOTE END--> <br><br>I don't know what kind of turbocharger you will use, but you will need more than turbo, ex-mani, boost controller and some hoses if you don't want to damage your new engine.<br><br>You will at least need high flow fuel pump, oil lines with fittings, some kind of fuel management(boost dependent if possible), boost gauge, A/F gauge(and/or EGT gauge) and some other small stuff. <br>Since most of wastgate is set at around 5-7 psi I don't think you will need a boost controller. <br><br><!--EZCODE QUOTE START--><blockquote><b><i>Quote:</i></b><hr> I'll add an intercooler if its too hot under the hood... <hr></blockquote><!--EZCODE QUOTE END--><br>Actually you will need bigger(or better) radiator and/or oilcooler if under the hood gets too hot. Intercooler won't cool down your engine. In most case, adding intercooler will create more heat under the hood by producing more power and usually also by blocking radiator.<br><br>Good luck on your project!! <p><b>Team Ukosias Racing</b><br>90 Tsi<br>97 Civic LX</p><i></i>
PostPosted: Mon Jan 21, 2002 6:59 am
go to this site <!--EZCODE AUTOLINK START--><a href="http://www.avoturbo.com.au">www.avoturbo.com.au</a><!--EZCODE AUTOLINK END--> they have turbo kits to bolt on with everything you need to run 5psi including 5th injector <p></p><i></i>
 Post subject: ...
PostPosted: Mon Jan 21, 2002 7:19 am
Thank you KickerGTi <p></p><i></i>
 Post subject: Low boost turbo
PostPosted: Mon Jan 21, 2002 3:08 pm
Your fuel system is good for up to 12 lbs of boost, provided you have a fuel pressure of 45 psi at full boost.<br><br>For your low setup you'll need the following:<br>1. Exhaust turbo manifold - Easy if you don't have A/C<br>2. A TO2 or TO25 turbine. TO3 is more common but for low boost you'll need a compressor A/R of 40 or 45 and an Exhaust housing A/R of 48 or 36 for a faster spool-up<br>3. Braided oil line with 1/8" AN fittings. Need to weld a 5/8" fitting to the crankcase for oil drain.<br>4. Intake Piping, and down pipe. Better to remove the cat.<br>5. Water lines if the turbine is water cooled. <br>6. As you'll be running low boost, a Blowoff/bypass valve is not mandatory. The wastegate can be either internal or external. You will be controlling the boost with it.<br>7. The stock cooling system is pretty good for your setup, provided it's in healthy shape.<br>With this setup you can run 6-7 lbs of boost easy, it depends on how healthy is your engine internally.<br><br>Anything else, just let me know, as I just turbocharged my Swift about 3 months ago. <p></p><i></i>
 Post subject: Re: Low boost turbo
PostPosted: Mon Jan 21, 2002 4:30 pm
what kind of torque/hp numbers would low boost 6-7-8-9 lbs<br>give the swift gti??<br><br> <p><P><A HREF="http://www3.telus.net/tc2468/">Tom's Webpage</A></P><P><A HREF="http://www3.bc.sympatico.ca/tc2468/swiftgti/ssgti90/ssgti90_pics.html"><IMG SRC="http://www3.bc.sympatico.ca/tc2468/small2.gif" BORDER=0 WIDTH=60 HEIGHT=45></A></P></BODY></HTML></p><i></i>
 Post subject: sweet
PostPosted: Mon Jan 21, 2002 4:40 pm
Yeah thx all for the info it's a great board <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p></p><i></i>
 Post subject: and...
PostPosted: Mon Jan 21, 2002 4:44 pm
Someone said it's easy to have an exhaust manifold if I don't have A/C or something like that...What do you means? <p></p><i></i>
 Post subject: Re: and...
PostPosted: Mon Jan 21, 2002 6:34 pm
so you don't have to worry about space. <p><b>Team Ukosias Racing</b><br>90 Tsi<br>97 Civic LX</p><i></i>
 Post subject: oh
PostPosted: Mon Jan 21, 2002 9:34 pm
And how many hp this setup provide?<br><br>PS im from quebec, canada and I speak french normally so my english is not so good...sorry <p></p><i></i>
