It is currently Tue Oct 17, 2017 4:56 am
 Post subject: daytona turbo
PostPosted: Tue Feb 19, 2002 9:23 pm
Hi guys, what do your think about this turbo? I really need some advice here cause I don't want to spend a lot of money...I found someone that makes manifold for 400$CAN. But now I need a turbo, DSM turbo are rare in my area(quebec)...Oh and someone know how much is for all the piping for the intercooler???<br>Thx <p></p><i></i>
 Post subject: Re: daytona turbo
PostPosted: Tue Feb 19, 2002 9:30 pm
I called today at a local shop in Montreal they seem to know what they are talking about. It's called Camo. you can find their number in the montrealracing.com shops listings <p>Never underestimate the power of a suzuki. you could be surprised...</p><i></i>
PostPosted: Tue Feb 19, 2002 9:58 pm
A little bit off-topic with my first thread but how many hp could I expect with 7Lbs of boost??? <p></p><i></i>
 Post subject: hey
PostPosted: Tue Feb 19, 2002 10:49 pm
A little bit off topic as well as not sure about turbo but the intercooler from it works fine. A few mods need to be done but is a nice thick one and doesnt take up too much room in our little beasts!<br><br>Just my lil tid bit!<br><br><br><br><br> <p></p><i></i>
 Post subject: Re: HP's at 7 psi
PostPosted: Wed Feb 20, 2002 6:38 pm
If you can make about 200 HP at the wheels with about 12-15 PSI of boost, I will estimate that at 7 PSI you should be at 130-140 HP at the wheels.<br><br>WIlfredo <p></p><i></i>
PostPosted: Wed Feb 20, 2002 11:13 pm
If your gonna use a DSM turbo get the 2G one. It's a T-25 and it's smaller than the 1G 14B's. The 14B would be way too big for the Swift. I know a bunch of ricers that use the T-25 on their Ci#ics. <p></p><i></i>
PostPosted: Fri Feb 22, 2002 8:05 pm
Anyone have step by step instruction to install manifold and turbo? I want to do it myself... <p></p><i></i>
PostPosted: Fri Feb 22, 2002 9:10 pm
Do a websearch HighTimes...<br><br>Quick point: you will have to do alot of custom modification<br>to your car to install a turbo. This is definately not a<br>'bolt-on' mod! Plan on sourcing out a custom turbo header<br>or building your own (to fit the turbo you find),<br>plus doing alot of other piping mods and possible<br>electronic engine control mods too! Pistons work sometimes<br>is needed and exhaust will need mating up to the turbo.<br><br>Good luck - I'd suggest you save roughly $3500US<br>to buy a custom setup or doing some research online to<br>find out how others have done turbo mods.<br><br>Darryl <p></p><i></i>
PostPosted: Wed Feb 27, 2002 5:27 pm
Senior Swift Guru
welding skills or a buddy who can weld, would be highly recommend for this. Even if you have the manifold built, there are still many other things like the intercooler and that which you would have to build.<br><br> <p><br><a href="http://www.teamswift.net"><img src="http://members.home.net/2832075173/pics/Swiftafter1c.jpg"></a></img><br>Kyle Jones <b>1989 Suzuki Swift GTi</b><br>Your friendly TeamSwift Op.</p><i></i>
 Post subject: HIGHTIMES17
PostPosted: Thu Feb 28, 2002 1:32 pm
DID YOU SAW YOU FOUND SOMEONE WHO MAKES A MANIFOLD FOR $400.00 CAN. WHO? THE CHEAPEST I FOUND WAS A TUBULAR CAST MANIFOLD FOR $540.00 US. <p></p><i></i>
 Post subject: Re: HIGHTIMES17
PostPosted: Thu Feb 28, 2002 5:59 pm
@92GT He's in Quebec (Canada) I don't know if he speek english but post your email and I'll you his #... <p></p><i></i>
 Post subject: good tricks
PostPosted: Thu Feb 28, 2002 9:13 pm
go to <!--EZCODE AUTOLINK START--><a href="http://www.flash.net/~lorint/lorin/turbo.htm">www.flash.net/~lorint/lorin/turbo.htm</a><!--EZCODE AUTOLINK END--><br>they give a lot of info on turbos what you need to know before you do the job.... <p>Never underestimate the power of a suzuki. you could be surprised...</p><i></i>
 Post subject: Re: good tricks
PostPosted: Fri Mar 01, 2002 3:02 am
Hey, i posted this link before but not sure where and since there is an ever increasing number of people that seem to want to turbo, here it is<br><br><!--EZCODE AUTOLINK START--><a href="http://sdsefi.com/techheader.htm">sdsefi.com/techheader.htm</a><!--EZCODE AUTOLINK END--> <br>and also check out the rest of their info as it will be a great help for the do it yourselfers out there<br><!--EZCODE AUTOLINK START--><a href="http://sdsefi.com/tech.html#Technical%20Updates">sdsefi.com/tech.html#Technical%20Updates</a><!--EZCODE AUTOLINK END--> <p><a href="http://members.home.net/imstaying">My GTi Page<BR><BR><BR><a href="http://members.home.net/imstaying"><img src="http://members.home.net/imstaying/images/my_gif.gif"></a></img></p><i></i>
PostPosted: Fri Mar 01, 2002 9:22 am
THANKS MY E-MAIL IS JBMCGALLI@YAHOO.COM I HAVE A FREIND THAT SPEAKS FRENCH. BUT LET ME ASK YOU IS IT A CAST MANIFOLD OR A HEADER. ALSO DOES HIS COMPANY HAVE AN E-MAIL ADDRESS IF NOT THATS FINE. <p></p><i></i>
