It is currently Fri Jan 19, 2018 9:56 pm
 Post subject: Car Backfires...
PostPosted: Fri Jun 20, 2008 9:36 pm
Any suggestions...My engine has been boosted for about 5 mts. (since it's rebuild again) but since then, when I accelerate aggressively I get the engine sounds as if it's backfiring for about 3 secs. then it smoothens out (this happens at about 5000 rpm). When I go over 5500rpm it smoothens out and gives good power. If I retard the timing it gets worst, and if I advance it, the backfiring stops. Is this normally experienced when the timing is backed down too far?. Should I just set the timing at 4BTDC and see the results? I'm running stock ecu, cultus cams n distributor, td04 turbo, a FPR set at about 56psi (on idle), the head was de-shrouded behind the exhaust valves, running about 7.5 psi
Any suggestions will be appreciated
ps. Before doing the rebuild, I had my stock solid cams with vitara pistons and running about 10psi. but never experienced this....
A wise man nor a fool cannot work without tools.
'93 GTI
'92 Mitsu Lancer
'86 Mazda 323
 Post subject: Re: Car Backfires...
PostPosted: Fri Jun 20, 2008 11:21 pm
maybe a bad distributor pickup? I had something similar, does your tach ever bounce?
the lolcar family
PostPosted: Sat Jun 21, 2008 12:26 am
And check your injectors, in case it's a fuel issue.
PostPosted: Sat Jun 21, 2008 6:26 am
The tach doesn't bounce or anything like that, I will have a look at the injectors
'93 GTI
'92 Mitsu Lancer
'86 Mazda 323
PostPosted: Sat Jun 21, 2008 12:48 pm
for what its worth, removing the injectors takes about 5 minutes, taking them to a diesel shop to get flow tested, cleaned, rebuilt and flow tested again costs 15/injector around here. I gained 12% flow on all 3 of them... just something to keep in mind
the lolcar family
PostPosted: Mon Jun 23, 2008 11:30 pm
You can also send them to WitchHunter. Sounds to me like the injectors could be the problem.
PostPosted: Tue Jun 24, 2008 10:14 am
why bother boxing them up and sending them away when you can get them done that day?
the lolcar family
PostPosted: Wed Jun 25, 2008 8:35 pm
Oh, I must have kind of skipped your original post. Does it misfire at high boost? Check your plug gaps. It sounds like you might be blowing out the spark.
I get that all the time if I don't check that the plugs are gapped tight enough.
PostPosted: Fri Jun 27, 2008 5:40 am
Rarson....U HIT the nail on the head!!!! It was only when the car got into or above 5psi would I experience the miss. I checked everything else before checking the Plugs, which I thought were good!!!
I pulled out the plugs and checked them...they were gapped at about...TOO WIDE...something like 40 - 50 might be even more. Anyways I replaced them with NGK#7's and gapped those to about 25 - 27. Man the car feels awesome again.
So thank you guys for all the suggestions and assistance...(anyone knows where I can get or recommend a good n fairly cheap piggy back!)
'93 GTI
'92 Mitsu Lancer
'86 Mazda 323
PostPosted: Sun Jun 29, 2008 12:33 pm
I currently have a Greddy Emanage blue installed in my car and love that little blue box,it controlls fuel and also ignition.
