It is currently Thu Jan 18, 2018 1:10 pm
Post new topic Reply to topic  [ 420 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 17  Next
PostPosted: Sun Feb 26, 2012 4:13 pm
Some tracker seats..much better seat..just gotta weld to metro sliders.
PostPosted: Sat Mar 03, 2012 10:05 pm
Tracker seat mounted to metro slider..feels good. Looks better..im about an inch higher but it suits my monkey arms and legs better...one more to go..
PostPosted: Sat Mar 03, 2012 10:34 pm
I like the adjustable headrest. Right now I'm using the turbo sprint seats. I just like to have my head always supported, I don't like to drive with my head forwards.
PostPosted: Sun Mar 25, 2012 2:44 pm
Wiperless..stock harness yanked...ill wire it myself with just the basics..and do wire tuck in bay..
Tip for running wires thru tube...tie a strand of yarn to wires(tape it too) insert yarn into tube..and chase it with compressed air..pull wires on through!...
PostPosted: Fri Mar 30, 2012 6:37 pm
alright..any of you gurus know which timing belt/ pump /gear combo to use? both 1.3 8v belts(round tooth) are too short with the 8v crank gear(round tooth)...1.6 16v belt is way too long..im wondering if tensioner placement on the 1.3 16v water pump is different... ive searched like hell..outside of some serious parts scrounging, im assuming the 1.3 16v belt is the one to use with a different tensioner or pump? stumped...thanks for any replies..
PostPosted: Fri Mar 30, 2012 7:06 pm
i did the mix and match timing component thing on my first turbo3 project and it was a ball buster getting just the right combo.
i haven't done a g13/ g16 head combo so i can't help.
i am paying attention, though. i'm a big fan of your projects. =)
PostPosted: Fri Mar 30, 2012 9:46 pm
I think the 1.3 16v has a different water pump/ tensioner position...gotta be the issue..ill run some part numbers tommorrow..ive used both 16v/8v belts and the tensioner would make the difference..crank pulleys are the same and cam pulleys are same diam and tooth count..
PostPosted: Sun Apr 01, 2012 2:03 pm
Problem resolved..hit the jy..eyed a 16v metro real good and robbed the belt..found out the parts store monkeys gave me the wrong belt twice...only took four different belts lol..
PostPosted: Sun Apr 01, 2012 2:04 pm
Edit..double post
PostPosted: Tue Apr 03, 2012 3:49 pm
Well heres a shot of where im at..makin good progress..a little each night...
PostPosted: Tue Apr 03, 2012 7:20 pm
Dash panels done...
PostPosted: Tue Apr 03, 2012 7:22 pm
Still have cup holders too!
PostPosted: Wed Apr 04, 2012 12:09 am
looks good, tell me, where did you get the 'dashmat' ?
PostPosted: Sun Apr 08, 2012 7:26 pm
Plumbing done..outside of a hump hose, transition hose, plug wires, and wireing..its ready to fire..
PostPosted: Mon Apr 09, 2012 7:23 pm
Road sign - patch pannels lol..
PostPosted: Wed Apr 11, 2012 3:48 pm
3/4" id oil drain..push lock hose..
PostPosted: Wed Apr 11, 2012 3:51 pm
Excuse the cob webs..its due for a good cleaning
PostPosted: Wed Apr 11, 2012 10:13 pm
Spent ten years racin with these boys..dodge...then am general..i was 12..dad was pit boss/ chase crew..this was shot in my garage during a trans change..which was routine with 800hp b1 big block power
93 parker400...THIS is my background..
http://www.youtube.com/watch?v=xyz8h_oz ... ata_player
PostPosted: Sat Apr 14, 2012 5:36 pm
The key to blow thru cv carbs...
The pilot tube...
float bowl vent tubes are plumbed into this pilot tube...the boost signal is more responsive this way and greatly helps the carbs transition into boost..it is well documented among turbo bike builders that this mod cuts main jet increase requirements nearly in half..it is proven stuff...
I tapped the plenum for a copper npt braze bung..and arranged two elbows to point into the air charge and sweated them into place...1/2" diam tubes...
PostPosted: Sat Apr 14, 2012 9:43 pm
Link to a page on blow thru cv carbs from a well respected fellow from theturboforums.com..this can be considered gospel...bob has done ALOT of sucessfully potent bike builds..enjoy..
http://www.unclebobsturbos.com/newbie.html
PostPosted: Mon Apr 16, 2012 7:18 pm
Float vent tubes referenced via pilot tube..obviously i need more god damned hose clamps.. :thwack:
PostPosted: Mon Apr 16, 2012 8:25 pm
rtsblwn wrote:
I want to pick up a control arm friday to begin jigging from for some fully adj. Tubular control arms with heims.
any progress on these? i'm tired of replacing control arms when the ball joints crap out every 2 years. i'd buy one lifetime set for my good car. :D
PostPosted: Tue Apr 17, 2012 4:53 pm
Money is just not there yet..hiems are pricey..jig is ready tho..im just tryin to get it drivable for now..its in the works...be patient my friend..youll like what i have brewing!
Arms...then lexan...then cage...then 225s and 240zg flares..it never ends..ive decided to keep this car long term to see how it evolves thru :the years... :blackeye:
PostPosted: Sun Apr 22, 2012 2:14 pm
Took out another 35 lbs of junk..gotta zolatone the floor..wireing underway..should be done by next sat (waitin on payday)..all factory wireing gone..gonna mount my distribution blocks on back of glovebox for quick service..single headlight..brakelights..horn, chargeing, start, and ign...just the absolute minimum..wanna be done by mid may if not sooner..gotta get some test n tune done befor the hooligan run june 2...
PostPosted: Sun Apr 22, 2012 3:09 pm
your radio reception is gonna' suck without an antenna. :-P
