It is currently Thu Jan 18, 2018 7:24 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Mar 21, 2010 11:40 am
This is my new project.
1480cc G13B with 79mm pistons
Pistons from pro light series standart size wiseco suzuki dr 350se (79mm), it has 20mm pin dimater.
Lightweight (-600gram) and polished crangshaft
Lightweight flywhell
Spoll H-Beam con rods
Engine block guard
Oil squirters
Titanium valves.
Titanium top locks
Titanium valve retainers
Polished head
Stage 3 Clutch set
Spectre Ems Pro ecu
4x450cc injectors
8x270cc injectors for methanol (standart gti injectors)
Adjustable fuel press regulator
36-1 trigerwhell
Walbro 255lph external fuel pump
Bosh 255lph external fuel pump
Custom 25L. fuel tank
IHI VB13 VNT turbo
Standart ART Dr350 pistons vs Wiseco Dr350
DR 350 79,5mm - 75mm ART Vitara - 75mm YCP D16 P29
Spool H-Beam vs Stock Polished Ssgti rods
275 cc Stock gti injectors
PostPosted: Sun Mar 21, 2010 11:45 am
Block with block guard
Lightweight and polished crangshaft
Titanium intake valves
Head
PostPosted: Sun Mar 21, 2010 12:13 pm
IHI VB13 VNT Turbo with ss ex manifold
PostPosted: Sun Mar 21, 2010 5:17 pm
all pretty cool..
ti valves suck (literally) for long term use however...( im a honda crf 450r owner) either way..pretty nice stuff.
PostPosted: Mon May 03, 2010 7:12 am
i have get 79 mm wiseco pro light sereries high cr pistons now. Pictures are show the deferences betwen vitara pistons.
My head have 27cc dead volume.
Piston have 5.125cc dome.
1.2mm head gasket volume 5,87cc
27-5.125+5,87=27,775 cc total dead volume.
Bore 79mm
Stroke 75,5mm
Cylinder volume = 79*79*3,14*75,5/4 = 369,884 cc
CR = (369,884+27,775)/27,775= 14,316
I can use diesel now :P :huh: :buzz:
PostPosted: Mon May 03, 2010 4:23 pm
MMmmmmm... Eye candy! :D
One question though, those H-beam rods are blowing my mind... how do you get the big end on the crank if it's one piece?!?
PostPosted: Mon May 03, 2010 9:17 pm
One piece? :huh: i can clearly see the bolts on my 240x320 screen :lol:
Suzuki Gold Master Tech
PostPosted: Mon May 03, 2010 9:33 pm
I can see the bolts, but i can't see the break for the life of me... maybe the fit is just perfect?
PostPosted: Tue May 04, 2010 1:14 pm
This bolts are not come with rods. i can't use this bolts.
i was order arp 2000.
PostPosted: Tue May 04, 2010 8:45 pm
The mad quebecer
The mad quebecer
Maybe it's just aging? I can clearly see the airline crack.
PostPosted: Thu May 06, 2010 3:07 pm
Okay guys
here's a joke me - LMAO...when I first got my Pauter rods some years ago, the machining was so fine that I couldn't see cap seperation [split] even after I removed the bolt. So, I e-mail pauter and view my concerns. The guy replied laughing with satisfaction saying that if I cannot see the split its because of the great work they do - LOL. He advised to tap the bigend slightly with a mallet and so I did - to my surprize there it was :mrgreen:
Some finishes make it impossible to see where the caps join.
PostPosted: Fri May 07, 2010 8:04 am
PostPosted: Fri May 07, 2010 11:41 am
Im
Press
Ive
PostPosted: Mon May 10, 2010 4:06 pm
I look forward to seeing this running, i wasnt aware that you could run 79mm pistons, did you have to resleave the block?
Boosted GTi
PostPosted: Tue May 18, 2010 3:30 pm
Crangshaft on balancing machine
Finaly i was rebore my block. it's now 79mm..
sleeve outside dimeter is 82mm.
PostPosted: Tue May 18, 2010 3:59 pm
I was resleeve block 5 years ago. I was complate remove stock cast iron sleeves and put in news.
Sleave outside dimater is 82mm, i can use 75mm inside dimater with vitara pistons past 5 years.
And now my bore size is 79mm with same sleeves.
PostPosted: Wed May 19, 2010 7:56 am
stock sleeves rebore to 75.50mm how much turbo pressure and how many hp without crack?? very interesting your project!!where you buy the sleeves?
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Wed May 19, 2010 1:56 pm
My old swift was only rebore 75.00mm stock seleeves. it take 1.4 bar peak 1.0 cont. turbo pressure with no problem.
custom orders are made on the production where i live
PostPosted: Sun Jun 20, 2010 4:43 pm
PostPosted: Sun Jun 20, 2010 4:48 pm
PostPosted: Sun Jun 20, 2010 4:53 pm
PostPosted: Sun Jun 20, 2010 4:56 pm
PostPosted: Wed Jul 07, 2010 3:39 pm
Nice engine!
my concern will Hi cr pistons and turbo mix? crank bolts are stock? will they hold that kind of force?
keep up the good work!!
PostPosted: Sat Jul 17, 2010 1:20 pm
PostPosted: Sat Jul 17, 2010 1:21 pm
