It is currently Thu Oct 19, 2017 4:37 am
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Jul 17, 2010 1:21 pm
PostPosted: Sat Jul 17, 2010 1:22 pm
PostPosted: Sat Jul 17, 2010 1:23 pm
PostPosted: Tue Jul 20, 2010 1:33 pm
ImageImageImageImage[URL=http://img96.imageshack.us/i/1005508k.jpg/]Image
[/URL]ImageImageImageImageImage
ImageImage]Image
PostPosted: Wed Jul 21, 2010 7:55 pm
nice work. looks like you have a sweet project going on. me like :D
92 swift ga coverted to gt. always a work in progress
PostPosted: Thu Jul 22, 2010 4:25 am
ONE OF THE BEST PROJECTS I HAVE SEEN :clap: :thumbsup:
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Fri Jul 23, 2010 12:57 pm
Where did you get the oil squirters from? :huh:
My cars:
PostPosted: Fri Jul 23, 2010 5:07 pm
Hey can you please shed some more details on the sleeves,we've bored the g13 upto 76.5mm and not beyond tht on stock sleeves,how can we get this done on our block,as i live in india
PostPosted: Fri Jul 23, 2010 5:11 pm
Did you have to notch the block for the h-beam rod clearance or do the rods fit without any machining to the block for clearance?
PostPosted: Sat Jul 24, 2010 3:28 pm
for h beam rods you need this on your block
<script src='http://img713.imageshack.us/shareable/?i=10042009993.jpg&p=tl' type='text/javascript'></script><noscript>Image</noscript>
the oil squirters greatly reduce the pressure of oil? I am thinking to put on my new turbo engine but then I'm afraid of not having oil pressure?!?"
PostPosted: Sun Jul 25, 2010 7:29 am
I have 79mm bor size. it have 2.5 mm space clearences to rods to seleves. But H-beam rods a little touch from under the seleves. A little shaving problem solved :D
PostPosted: Sun Jul 25, 2010 7:43 am
I'm put them out standart seleves, and pressed new custom seleves.
Outside dimeter 82mm
Inside dimeter 79mm
They have only 1,5mm thickness but i have block guard.
PostPosted: Sun Jul 25, 2010 7:50 am
4 cyl renault kango or megane diesel engines squiters. 1.5dci or 1.9 dci, i don't remember which one :)
They are press fitted. If you use standart crang do a little modification to squaters because they are touch crang counterweights or under the piston. If you have knived edge crang counterweight, they are perfect fit.
PostPosted: Sun Jul 25, 2010 7:59 am
PostPosted: Sun Jul 25, 2010 8:00 am
PostPosted: Tue Jul 27, 2010 7:03 pm
Hey i understand u used new sleeves,those are available here on custom size order,my question is how did you completely remove the original sleeve? please can you post a picture of that,im sorry is these questions come across as stupid to you,its just that where i am from,we have bare minimal support for all these jobs,so just looking for some help,if any of you guys can also post some valuable info i would be very grateful to you'll,thanks in advance,cheers..!
PostPosted: Wed Jul 28, 2010 7:05 pm
Bump!
PostPosted: Thu Jul 29, 2010 8:19 pm
:lol:
Well if you happen to find another set... :mrgreen:
My cars:
PostPosted: Sun Aug 08, 2010 7:13 pm
Bump for updates..!
PostPosted: Tue Aug 31, 2010 10:32 am
some news??
PostPosted: Mon Sep 06, 2010 3:49 am
Seems like gt_ is on a break,we are very eager for updates,hoping this BUMP gets a positive response!
PostPosted: Tue Sep 07, 2010 7:29 pm
PostPosted: Tue Sep 07, 2010 7:31 pm
PostPosted: Tue Sep 07, 2010 7:32 pm
Sory for delay..
Ecu wiring becomes nightmare :) But i finished this monday.
I'm start assembly to water injection system.
Users browsing this forum: Exabot [Bot] and 3 guests
