It is currently Fri Oct 20, 2017 9:07 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Sep 18, 2010 6:09 am
hey can you please post some pictures of the block when you go the stock sleeves removed or can you shed some more info on how you pulled out the stock sleeves,because as far as i know the stock sleeves are poured into the block while its made,so it becomes a part of the block right?
PostPosted: Sun Sep 19, 2010 9:36 am
Yes it becomes a part of the block but it's easy to remove with machining.
Rebore to come from aluminium block.
Order the new seleves like one. This is not actual photo i find it web.
Then alitle heat the block and put in new sleeves.
PostPosted: Wed Sep 29, 2010 5:12 am
My new NGK BKR6EQP Laser Platinium series spark slugs.
custom gas tank
PostPosted: Wed Sep 29, 2010 10:16 am
I have had good luck with the BKUR6ET-10 plugs, 7 plugs ran good at speed but fouled like a mofo when idling.
If you want to use something a little cheaper than the fancy pants Laser Platinum ones, they are basically just the regular plugs but semi-surface discharge. The BKUR6's are the factory units in VW 2L AEG engines, and they do a very good job there as well.
My cars:
PostPosted: Mon Nov 08, 2010 4:57 pm
new pics or videos ?!?!
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Tue Jan 04, 2011 4:49 pm
news?? broken engine? :lol:
PostPosted: Tue Jan 04, 2011 6:35 pm
Any good engine shop can do this - I had one replaced after scoring damage - pretty cheap I think $150.00 total
90 Swift GT - GT-BBT25 turbo Red - For Sale
99 MX-5 10th AE Saphire Blue
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Fri Dec 30, 2011 8:00 pm
is this running now?
Boosted GTi
PostPosted: Sat Dec 31, 2011 2:28 am
custom gas tank
do those platinum laser series require electrode gapping ? i usually gap and check mine every 1000K
PostPosted: Sun Dec 30, 2012 11:24 am
amazing !!!! congrats!!
power intend to get there?
Users browsing this forum: Google [Bot] and 4 guests
