It is currently Mon Oct 16, 2017 7:09 pm
PostPosted: Mon Jul 12, 2010 1:31 pm
Anyone ever done it before? I'm putting a G13B in my Samurai and I'm going to turbo it at the same time. My goals for this setup are going to be quick boost, keeping it under 12 lbs max probably. Just wondering what the boost threshold would be for a tiny turbo on a GT engine.
PostPosted: Tue Jul 13, 2010 12:48 am
No, it's already small for the G10 engine, sell it and buy a proper sized turbo. I'm sure someone else will recommend a more suitable one for you.
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Wed Jul 14, 2010 11:57 am
If you have two of them, it'd probably work for a twin turbo setup...
1+3 feed turbo 1
2+4 feed turbo 2
Would require lots of work though.
PostPosted: Wed Jul 14, 2010 12:27 pm
I don't have a turbo yet, just trying to decide on which one to look for. My GT doesn't hit peak boost until about 4k RPM (IHI RHB5), and I would like the Samurai on peak boost at half that RPM, even if it runs out of steam a bit on top as it will have an off road emphasis.
PostPosted: Wed Jul 14, 2010 1:58 pm
Get a GT2554R - http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT25/GT2554R_471171_3.htm
PostPosted: Wed Jul 14, 2010 2:53 pm
Paul Jr.
Read this and attempt the semi-rocket science math to find your ideal turbo, it will help a great deal:
http://teamswift.net/viewtopic.php?f=6&t=23530
PostPosted: Fri Aug 20, 2010 10:21 pm
I have tried a stock MK2 turbo on a G13 before. It worked up to 5 PSI and 5000 RPM, after that all hell broke loose...
PostPosted: Fri Aug 20, 2010 10:42 pm
I bet it'd full boost by 2,000RPM and vent excess to prevent surge.... The wastegate might not be able (flow enough) to keep it under surge.....
PostPosted: Sat Aug 21, 2010 1:00 pm
What do you mean by all hell broke loose? Boost creep?
PostPosted: Sat Aug 21, 2010 11:48 pm
More like blew the crap out of the turbo lol... It was glowing under the hood :lol:
PostPosted: Sat Aug 28, 2010 12:00 pm
two words no flow=heat heat more super heating of the inlet air! try tdo4hl-13g or t-25(cheapie's) best GT2554R,tdo4hl-15g,T-28...etc quick spool 2500rpm up bigger t-3 42.cold .48 hot(saab)search is key!
Bong,Bong,Bong....zuki's
PostPosted: Wed Sep 15, 2010 2:13 pm
T28? quick spool? :huh:
Suzuki Gold Master Tech
PostPosted: Thu Sep 16, 2010 9:57 am
Thats why I was thinking- I had a T3 on my GT for a while, and that thing was LAGGY. Wouldn't imagine a T28 would be much better than that.....
