It is currently Fri Oct 20, 2017 3:11 am
PostPosted: Mon Aug 23, 2010 12:37 am
where do you tap the oil and water for a turbo on a g10? i cant figure out how to use the search efficently
thanks
PostPosted: Mon Aug 23, 2010 7:51 pm
Oil you can tap at the port right next to the oil pressure sender. As for water, I put a t fitting where the water leaves the block, right in front of the thermostat, and goes out a 1/2 inch or so heater hose to the heater core. As for the return, I just put another t on the out side of the heater core line. Worked fine for me for nearly 2 years, and a perk is that winter time means that the water is just a tad warmer, much needed in Pennsylvania :lol: :lol:
Hope that helped
Robert
PostPosted: Thu Aug 26, 2010 2:48 am
that did help! thanks! finished putting it in and it really isnt that much faster since its only running about 3psi. i just made a T connection off the oil sender since the plug next to it wouldnt budge. tbi pretty much means im stuck running low boost if i dont want to dump alot of time and money at it?
PostPosted: Mon Aug 30, 2010 5:42 am
I am running 7-8 constantly in my tbi, never had an issue except when I used cheap head gaskets(NEVER NEVER NEVER use ebay "evergreen" gaskets, Felpro only) I have cracked the boost up to 10 and have not had an issue.
Check my videos on youtube http://www.youtube.com/watch?v=ukqVkcPDURc
:lol:
