It is currently Wed Oct 18, 2017 8:52 am
PostPosted: Thu Sep 02, 2010 10:54 am
does the g13 throttle body have larger injector? would it be an upgrade on a g10 thats turbo? :huh:
spencer
PostPosted: Thu Sep 02, 2010 1:24 pm
Assuming you're referring to the TBI versions, I've measured them both and they are dimensionally identical. My guess is they are exactly the same unit and only the pulse width is lengthened to accommodate the extra cylinder. Real TBI gains will come from you porting the daylights out of both upper and lower TBI castings and bridge removal.
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Fri Sep 03, 2010 4:06 pm
They are the same injectors. The injector(blue) from the TBI G16 (trackers, sidekicks etc....) will fit in the g10 tbi. BUT... you have to mod the top as the 1.6 injector has a wire lead and the g10 has the pins on top. I have been toying on this idea for a while as I have a turbo tbi. I have it on the spare engine, I am just waiting for this motor to go so I can swap. You can expect a drop in mileage(BAD) because the injector will spray more volume per pulse vs the stock g10 injector. not a problem when you are on boost. .....
that project went on hold as I just bought a 89 swift gti :lol:
Users browsing this forum: No registered users and 8 guests
