It is currently Sun Oct 22, 2017 2:15 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 04, 2012 1:02 pm
OK...I dont know if I understand correctly but i dont check the load, im using weber carburators and just ignition control should be electrical controlled...
So maybe the checking of load is so inportant i can use pressure sensor and thats can make corection on my ignition map....but i think it is a future...first im just need start my engine:)
PostPosted: Wed Apr 04, 2012 1:06 pm
yes i forgot...100oct is obvious and CR 11.4:1 and no turbo
PostPosted: Wed Apr 04, 2012 1:18 pm
Im just speakin of load as in throttle position as they sre directly related in termas of vaccume/boost..
PostPosted: Wed Apr 04, 2012 4:12 pm
Senior Member
gabo00000 wrote:
Hello!
Im from slovakia and i has very bad english bud i hope you can help me.
I build a G13B engine for my 4x4 suzuki swift and i dont use the original ignition.
I have a programmable unit but I do not know what values ​​i must to enter.
I search o lot but I cant found the original ignition table.
Can you help me with this?
I know that the original values ​​are not good for me but I use them only as a basis, for starting the engine.
Thanks
I am with Gabo, anyone using after market engine management on a non turbo'd engine? I am beginning to think that there should be a place on this board where all of this useful information is stored....
Because what I read above is gold. (yeah I know, each setup is different, each setup should get a professional dyno tune blaa blaa... but it is still gold,. Especially when our esteemed members list the salient engine characteristics with the maps...
Next time guys, add the cam profiles :-)
PostPosted: Thu Apr 05, 2012 5:39 am
I was thinking about this issue and Ive found that no matter the throttle position because this engine will not used for routine driving...It will be used only for racing...it means...still full load
Now let's go to the beginning...I just need original ignition map ... something like this....
...if it is a problem, i sarting from zero...
2874_2007-01-10_10-19-38_2.JPG [17.63 KIB]
Downloaded 230 times
PostPosted: Thu May 17, 2012 11:48 pm
Here is the eom 16x16 ignition table. The nominal rpm numbers where plugged in for demostration purposes only and may not represent the actual rpm range eg - 500rpm may actually be 1000rpm.
What type of ignition system are you using? Electromotive?
StockIgnA.png [47.2 KIB]
Downloaded 210 times
cron
