It is currently Sun Oct 22, 2017 11:40 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Turbo Manifold Thread
PostPosted: Mon Oct 18, 2010 11:44 am
Show us a pic of your turbo manifold setup lets see whats out there
I'm in love with turbine tech's setup but it cannot work with A/C :(
PostPosted: Wed Oct 20, 2010 4:03 pm
We have a Stage 2 AVO-Turbo kit out of Australia. We are able to retain the AC, whcich BTW is the massive SD-505 R12 type compressor! it would clear the Suzuki compressor with easy. we used the SR20DET OEM downpipe and used a remote oil filter relocation kit at the time. recently we removed the relocation kit because the size fittings we causing sever pressure loss. back to using the Suzuki OEM filter!
1994 Suzuki Swift GTi
PostPosted: Thu Oct 21, 2010 5:24 am
PostPosted: Thu Oct 21, 2010 6:22 am
:D Can you send a link?
Can't find the GTi kit on any of the AVO turboworld websites. Most info I can find online about the kit is this article.......... http://autospeed.com/cms/title_Mr-GTi/A ... ticle.html
Also, how hard is it to remove the oil filter with everything assembled?.............It seems to be a tight squeeze..And are those heat shield bolt hole in the manifold?? :P
PostPosted: Fri Oct 22, 2010 6:12 pm
Just also found out that Suzitech makes a turbo manifold to accomodate A/C also
Anyone ever used one?
PostPosted: Fri Oct 22, 2010 7:33 pm
I responded to your PM KIDmar. You must the OEM sized Oil filter to clear the SR20 downpipe. We tried to utilize a heat shield by welding those nuts onto the manifold, it didn't quite work out, lol.
PostPosted: Fri Oct 22, 2010 7:57 pm
Thanks....So since you said SR20 I'm assuming your using a Garrett GT25-60R turbocharger?
PostPosted: Sat Oct 23, 2010 7:52 am
Turbine tech equal lenght manifold with external wastegate
1993 boosted Suzuki Swift GT
PostPosted: Sun Oct 24, 2010 2:18 pm
I wonder if you can rotate the turbo 180* so the turbine side faces the front of the motor if it would clear the A/C compressor with the turbine tech manifold :huh: ...I LOVE that turbo manifold from Turbine Tech
PostPosted: Sun Oct 24, 2010 6:08 pm
The mad quebecer
The mad quebecer
Then the turbo would hit the rad. I see no good retaining AC if you don't have a radiator to cool the engine down in the first place :mrgreen:
PostPosted: Sun Oct 24, 2010 7:29 pm
The Smuggler
Anyone got one of these on their G13B?
And I love this one!
PostPosted: Sun Oct 24, 2010 8:54 pm
YOU GUYS NEED TO MAKE A MANIFOLD TO SUIT A/C :evil:
PostPosted: Mon Oct 25, 2010 7:12 am
Is that the SRD manifold?
I read a guy used it and it didn't work with his a/c system. The page says it can be used with a/c if desired
PostPosted: Mon Oct 25, 2010 9:33 am
The Smuggler
No this is a treadstone manifold.
PostPosted: Mon Oct 25, 2010 5:08 pm
The mad quebecer
The mad quebecer
That's because the manifold has little to do with a/c fitment. Turbo selection, downpipe and CAI is what really matter. A small K03 turbo is about the only dryer you could fit in there.
PostPosted: Mon Oct 25, 2010 7:37 pm
You guys make a manifold for it? :D
PostPosted: Mon Oct 25, 2010 9:14 pm
The mad quebecer
The mad quebecer
Yes we do. But I don't think someone would pay for it :ez_pimp:
PostPosted: Mon Oct 25, 2010 9:20 pm
I think the turbo location has something to do with the manifold :huh:
Suzuki Gold Master Tech
PostPosted: Mon Oct 25, 2010 9:48 pm
The mad quebecer
The mad quebecer
a little.... but turbo sizing is what really matter, along with the proper downpipe and CAI setup. The manifold comes last in my opinion.
PostPosted: Tue Oct 26, 2010 5:02 am
Once its a proper built manifold, I wouldn't mind paying the price on it if my funds allow me...
PostPosted: Tue Oct 26, 2010 5:46 am
Id advise against the suziteck manifold
PostPosted: Tue Oct 26, 2010 8:09 am
The mad quebecer
The mad quebecer
Well well..... you complain about us not making a manifold for A/C ?? I just quoted you for a complete A/C setup including manifold, turbo, downpipe with CAI and you say there is no funding available..??
Go figure....
PostPosted: Tue Oct 26, 2010 10:15 am
Go figure....
I said you could make a manifold, never said when :wink:
PostPosted: Tue Nov 16, 2010 1:22 am
I wouldnt reccomend it unless you block off the wastegate and use an internal. See how the wastegate port is on one runner? That wont allow for proper operation in bypassing the turbine.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Thu Nov 18, 2010 5:32 pm
my turbo manifold for external wastegate
<script src='http://img824.imageshack.us/shareable/?i=230520091061.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img203.imageshack.us/shareable/?i=dsc00339bp.jpg' type='text/javascript'></script><noscript>Image</noscript>
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
