It is currently Fri Jan 19, 2018 10:22 pm
 Post subject: new turbos
PostPosted: Sun Oct 24, 2010 1:35 pm
9yo kid ?
I had a tdo4h-13c and a tdo5-12b running compound boost at 24 lbs...Had way to many problems taking off in 1st gear, But trap speeds were a high of 111.650 1/4 mile time is no importance....Have bought 2 new turbos for 40. bucks...td04 hl 15g....does anyone know the max boost on these turbo's
 Post subject: Re: new turbos
PostPosted: Tue Oct 26, 2010 10:04 pm
Main twit
who did the work on your car? im interested in contacting them to do some work on mine.
Tim
MT Motorsport
www.mtmotorsport.ca
PostPosted: Wed Oct 27, 2010 2:42 pm
9yo kid ?
I did the work....What you are actually looking at is the aftermath of sliding sideways across the 1/4 mile at 106.70 and nailing the wall at around 90 or so mph...That is why I am putting on new turbo's...The wall broke the td04 in half
PostPosted: Thu Nov 18, 2010 2:22 pm
Nice one running two turbo in series. LOL. We run more than 58Psi making the dyno do this. :drunk: :mrgreen:
http://www.youtube.com/watch?v=WY2GYQG4 ... r_embedded
We rune some td04 hl 15g on 14 to 15PSI max. To bad Molinari dos not make small clutches otherwise you could take of in second gear
http://www.adaptronic.nl Official Whiteline dealer. For more info adaptronic@gmail.com
Official Innovatemotorsports dealer
Tech Edge o2 sensor kits.
PostPosted: Fri Nov 19, 2010 2:07 am
It all depends on the engine and efficiancy. On the 3000gt a pair of hl 15gs will support about 24 psi to 7k (1.5 liter per turbo)
Keep in mind psi is resistance to flow. With some head work the 15gs will only make about 20 psi but will make similar power.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Mon Nov 22, 2010 10:21 pm
9yo kid ?
So About 3 yrs ago I had the Head ported...I put Block hardner in coolant passages...Studded it...Bored 40 over...Vitara pistons...New mains and rod bearings...Dual diaphram Pressure plate...Dual 4 puck disk...Had way too much Boost on the lower end....Smoked the wheels all the way thru 1st gear barked in 2nd and 3rd and still ran 111 mph 1/4 mile...my times Sucked...Am hoping for Boost to kick in around 2500 rpm or so...I here these turbos Boost to 8000 rpm ... Man this would be Nice...we shall see...If numbers are right I will Supposedly be boosting around 31 to 33 lbs ,,, I used to have 24lbs....The funny part of this is...the motor Is still awesome...WHAT a working machine for what I have put it Thru........DRAG race only!!!....Amazing...and Cheap
