It is currently Tue Feb 20, 2018 10:38 am
 Post subject: I need turbo help.
PostPosted: Fri Dec 10, 2010 11:51 pm
I am going to go turbo on my 95 Metro G10. I am going to be rebuilding the head and setting it up for port injection and running a MegaSquirt. I want to run 6-8 psi, what size turbo should I use? I plan on doing this as cheap as possible, but I want to do a decent job as well.
 Post subject: Re: I need turbo help.
PostPosted: Sat Dec 11, 2010 8:12 am
RHB3/RHF3 is perfect for that application, but not cheap.
Stay as close to that size turbo as possible.
PostPosted: Sat Dec 11, 2010 2:04 pm
a bump up to an rhb5 like from a mazda mx6 or turbo probe will be easier to find in a wrecking yard here in the usa. a t25 from a saab is good pickins', too.
an rhb3 down here is as rare as hens' teeth these days.
PostPosted: Wed Dec 15, 2010 8:38 pm
im new to this site, not sure if this is posted in the right spot. im thinking of turbo charging my 96 metro 1.0. i will be rebuilding the engine first, what are the neccesary mods? special head gasket? ect anyone using the 3tech head? i have a turbo from a 1.8 vw jetta gas engine that i planned to use. any info is apriciated. i am a profession mechanic i just need to know how much this little motor can take. it will be a daily driver i just want a some passing power.
PostPosted: Wed Dec 15, 2010 8:59 pm
some guys have turbocharged the standard g10 using the existing pistons and connecting rods, the rods probably being the biggest limiting factor for power - at some point they're likely to fold up.
the oem turbo3 uses beefier rods, shared with the g13 twincam, and dished pistons that give a lower (8.5:1) base compression ratio. the factory turbo3 also uses a multiport fuel injection system, 3 separate injectors plus a cold start fuel enrichment injector. the electronic engine controls use a vane type air flow meter and the ignition is a little hotter, using a discrete, externally mounted ignitor.
in my opinion, the biggest hurdle is engine management/ fuel management. figure on using a high flow fuel pump (the stock 3 banger pump won't cut it) and an external fuel pressure regulator. be aware that you'll be pretty much on your own for tuning.
have fun, good luck, and keep us posted. :wink:
PostPosted: Sun May 22, 2011 8:26 pm
Would a T25 from an Eclipse or something the like work?
