It is currently Sat Feb 17, 2018 7:27 pm
PostPosted: Fri Jan 14, 2011 4:39 pm
hi,
i have a 1990 suzuki sj413 with a 1.3 G13A ive been told some of the swifts has the same engine :? , on the sj forums nobody wants to help me because they dont see the point of turboing a sj :? ive borght a garrett t15 turbo but will the stock internals take that ??? any help would be great!!!
many thanks ,ben :D
PostPosted: Fri Jan 14, 2011 5:38 pm
From memory the g13a has a hollow crank and fixed pin pistons which means you wouldn't want to run much boost, 4-5 psi, find yourself a twincam g13b engine and swap crank, rods and use vitara pistons for a strong bottom end.
PostPosted: Fri Jan 14, 2011 5:39 pm
10 should be no problem, as long as it's fueled, and ignition is right.
PostPosted: Fri Jan 14, 2011 6:08 pm
agreed. ive done 20psi pulls many times on vitaras and gti rods with the hollow crank no problem..even 8200 rpm...tough little bastards
PostPosted: Sun Jan 16, 2011 4:18 pm
thanks for the help ! im having trouble with a few things wondered if any of you could help ?
where do i take the oil from for the oiling the turbo??? and on the original exhaust manifold there is a little hold at the gearbox end what is it??? looks like a breather or a vacunm or somthing do i need to incorpurate this when building the turbo manifold???
PostPosted: Tue Jan 18, 2011 6:44 pm
egr
