It is currently Sun Jan 21, 2018 12:05 pm
 Post subject: motor swap
PostPosted: Tue Feb 08, 2011 10:40 pm
I am not sure if I am posting this in the right spot? I have a 99 firefly 1L and want to know if an 87 turbo 1L sprint motor will bolt up to my belhousing. Not worried about ECM or fuel pressure (minor details) I am sure this info is on the board somewhere just can’t find it.
Ahren
 Post subject: Re: motor swap
PostPosted: Wed Feb 09, 2011 12:31 am
Yes
PostPosted: Wed Feb 09, 2011 9:01 pm
Thanks
