It is currently Tue Oct 17, 2017 4:03 pm
PostPosted: Mon Feb 14, 2011 6:16 am
hi
im from portugal and im buiding a new engine for my swift for street/drag car.
some specs and pics:
- G13b block
-Custom CP forged pistons
-Port and polish head
-3 angle valve job
-Camshafts -Catcams
-Forged rods
-ARP 2000 rod bolts
-ligther crankshaft pulley
-oil pump
-Junta cabeça mls /multilaminas em chapa
-Junta colector de escape em chapa
-Polies de afinaçao
-exaust turbo maifold /home made
-intake manifold-
-TB 60mm
-ACT clutch extreme -600hp
-exaust 60mm inox
-Injectors 670cc precision
-fuel pump 255lph
-fuel pressure regulator-Regua de injecçao modificada
-Short shift
-oil radeator
-oil sanduich mocal
-cold spark plugs
-TURBO and COMPONENTS:
-Precision 5857
-tubagens 60mm
-ebay dumpvalve
-ebay wastegate externa
-intercooler frontal fmic
electronic:
-omex 600 ecu
-Cabos de vela Magnecor silicone 8mm
- Ford coil
-honda air tempeture sensor
-cranckshaft sensor
-knock sensor
-tps sensor honda
-Map sensor 3 bar
- 75 AMP alternator
brakes and suspencion
-yelow koni sport shockss
-apex 60 mm
-front bar Cusco
-driled and razor front rotors-Discos oem traz
- front kevlar apex pads
-ferodo premium rear pads
-dot 5.1
-15 oz rims
- nakang tires 195/45/15
<script src='http://img137.imageshack.us/shareable/?i=dsc00652y.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img291.imageshack.us/shareable/?i=dsc00655wn.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img11.imageshack.us/shareable/?i=dsc00657pl.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img513.imageshack.us/shareable/?i=dsc00659r.jpg' type='text/javascript'></script><noscript>Image</noscript>
bielas h-beam fotjadas testadas para 11000rpm
<script src='http://img600.imageshack.us/shareable/?i=dsc00828b.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img829.imageshack.us/shareable/?i=dsc00831f.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img204.imageshack.us/shareable/?i=dsc00835fv.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img40.imageshack.us/shareable/?i=dsc00834ch.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img214.imageshack.us/shareable/?i=dsc00807s.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img600.imageshack.us/shareable/?i=dsc00809f.jpg' type='text/javascript'></script><noscript>Image</noscript>
reforço rectificado para as bielas nao baterem
<script src='http://img404.imageshack.us/shareable/?i=dsc00812oc.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img684.imageshack.us/shareable/?i=dsc00839y.jpg' type='text/javascript'></script><noscript>Image</noscript>
Para as mas lingues que nao se acreditao no poder dos blocos 1.3
<script src='http://img341.imageshack.us/shareable/?i=dsc00842y.jpg' type='text/javascript'></script><noscript>Image</noscript>
A bela da junta mls
<script src='http://img832.imageshack.us/shareable/?i=dsc00846t.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img826.imageshack.us/shareable/?i=dsc00844w.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img641.imageshack.us/shareable/?i=29072008765.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img42.imageshack.us/shareable/?i=29072008766.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img825.imageshack.us/shareable/?i=dsc00362al.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img835.imageshack.us/shareable/?i=dsc00364z.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img155.imageshack.us/shareable/?i=dsc00366yz.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img80.imageshack.us/shareable/?i=dsc00814tg.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img227.imageshack.us/shareable/?i=dsc00820kw.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img26.imageshack.us/shareable/?i=dsc00933eo.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img641.imageshack.us/shareable/?i=dsc00847dv.jpg' type='text/javascript'></script><noscript>Image</noscript>
knock sensor
<script src='http://img20.imageshack.us/shareable/?i=dsc00853f.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img96.imageshack.us/shareable/?i=dsc00852ys.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img694.imageshack.us/shareable/?i=dsc00851g.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img143.imageshack.us/shareable/?i=dsc00856o.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img835.imageshack.us/shareable/?i=dsc00855me.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img812.imageshack.us/shareable/?i=dsc00095t.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img143.imageshack.us/shareable/?i=dsc00097ul.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img25.imageshack.us/shareable/?i=dsc00859dr.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img822.imageshack.us/shareable/?i=dsc00858a.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img148.imageshack.us/shareable/?i=dsc00956ff.jpg' type='text/javascript'></script><noscript>Image</noscript>
AINDA DIZEM MAL DAS DO MK2 :)
<script src='http://img189.imageshack.us/shareable/?i=dsc00955xh.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img687.imageshack.us/shareable/?i=dsc00957nr.jpg' type='text/javascript'></script><noscript>Image</noscript><script src='http://img189.imageshack.us/shareable/?i=dsc00962js.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img141.imageshack.us/shareable/?i=dsc00967c.jpg' type='text/javascript'></script><noscript>Image</noscript><script src='http://img706.imageshack.us/shareable/?i=dsc00965ug.jpg' type='text/javascript'></script><noscript>Image</noscript>
O VERDADEIRO :)
<script src='http://img193.imageshack.us/shareable/?i=dsc00969my.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img689.imageshack.us/shareable/?i=dsc00972zc.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img832.imageshack.us/shareable/?i=dsc01164m.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img832.imageshack.us/shareable/?i=dsc01170k.jpg' type='text/javascript'></script><noscript>Image</noscript>Image
Uploaded with ImageShack.us
<script src='http://img97.imageshack.us/shareable/?i=dsc01175u.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img703.imageshack.us/shareable/?i=dsc01173c.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img97.imageshack.us/shareable/?i=dsc01171sn.jpg' type='text/javascript'></script><noscript>Image</noscript>
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Tue Mar 15, 2011 5:33 pm
hey man very nice project so what gearbox are you running with and how much boost r u running
