It is currently Thu Feb 22, 2018 2:34 pm
 Post subject: factory bearings
PostPosted: Wed Oct 05, 2011 5:24 pm
This might be a stupid question but i was trying to order a set of bearings from the dealer for the 1.6 and they needed to know what color bearings they were. Why do they have different bearings but all aftermarket are the same??? What is the difference in theyre bearings. IS it size or how hard they are??? Thanks Stephen
 Post subject: Re: factory bearings
PostPosted: Wed Oct 05, 2011 8:50 pm
Size. Different colours will provide different clearance. It's like the number system on the pistons.
PostPosted: Fri Oct 07, 2011 8:01 am
What type of clearance are you guys running on your motors??? and which colors are you guys using???
PostPosted: Sat Oct 08, 2011 7:06 pm
you have numbers on the crank and the block, and there is a chart on what color (size) to use in each mains.
when you order aftermarket bearings you get all the same thickness, and different clearances, with low oil pressure as a result.
Suzuki Gold Master Tech
PostPosted: Sat Oct 08, 2011 7:15 pm
Only if you have a problem, or are quite a bit outside factory tolerance.
PostPosted: Sat Oct 08, 2011 7:55 pm
ok. well when the block and crank get here at the beginning of the week ill get the numbers.
PostPosted: Sun Oct 09, 2011 12:09 am
The comparison of its stampings with the block stampings will only work if both block and crank are new / unworn. Crank wear will increase the bearing clearance ... So your best bet is measure the clearance on any bearings you use.
What I did on my rebuild was to put a bearing of the "correct" clearance based on crank / block stampings on each journal and use plastigauge to measure the actual clearance. The actual clearance was used to recalculate the colour bearing that was required. If you have the proper measuring tools, you can measure block and crank and do the calcultions no test bearing required.
The race is not for the Swift ... yeah right ;) !!
