It is currently Wed Feb 21, 2018 2:26 pm
PostPosted: Fri Nov 18, 2011 12:38 am
What can be done to the 1.0 to strengthen it? How much boost can the the stock bottom end handle? I read about Vitara pistons all over here, but do they only work with the G13? If they will work, what rods would work with them?
Thanks,
Jordan
PostPosted: Fri Nov 18, 2011 11:56 am
Search. Most of this information is here.
PostPosted: Mon Nov 21, 2011 10:42 pm
I have done a lot of reading, most of the useful information that I have found has been for the 4 cylinder. But thanks, I guess.
PostPosted: Mon Nov 21, 2011 10:53 pm
Check with t3 ragtop.
He has some modest experience with the 3 cylinder and has a brief thread on how to pump it up, including a turbo.
With any luck, you can just buy his!
PostPosted: Mon Nov 21, 2011 11:08 pm
What kind of power would you like to make?
The stock motor is easily good enough for 10+ psi, as long as you time and fuel it right.
PostPosted: Tue Nov 22, 2011 12:13 am
Going to be 15+ psi, will the stock g10 internals take this? What would have to be done to safely run up to 20psi?
Users browsing this forum: Cysiu and 2 guests
