It is currently Wed Jan 17, 2018 2:54 am
PostPosted: Thu Jan 05, 2012 6:24 pm
Hi, i was wondering if a turbo setup would run ok if i upgrade to bigger injectors and standalone ecu but leave the rail and fpr as stock?
Boosted GTi
PostPosted: Fri Jan 06, 2012 5:14 am
You will potentially get to a point where fuel rail might be restrictive (mk1, mk2 and mk3 rails have some variation and hence dont all flow the same amount of fuel) but no other real issues using standard rail with larger injectors. I have previously run 390cc injectors with standard mk3 rail and second setup with standard rail and fpr.
ImageET 13.138 at 120.2mph
Users browsing this forum: Yahoo [Bot] and 2 guests
