It is currently Sat Jan 20, 2018 4:34 pm
PostPosted: Mon Feb 20, 2012 7:36 am
MY SWIFT 1.3 GTI TURBO
some specs of engine
ENGINE
-CP forged custom pistons
-full port and polish head
-3 angle valve job
-Cams -Catcams
-forged rods
-ARP 2000
-Polie cambota + leve
-Volante de motor - 1.3kg
-MLS head gasket
-Polies de afinaçao
-custom exaust manifold
-custom intake manifold
-60mm TB
-CLUTCH ACT extreme 4PU
-Apoios motor reforçados
-70MM EXAUST
-Injectors 670cc precision
-fuel pump 255lph
-FSE
-Short shift
-MOCAL oil cooler
-spark plugs bpr8es
and some more stuff
-TURBO
-GARRETT T3/T4 AR63
-XS dumpvalve
-TURBOSMART WASTEGATE 38mm
-EBAY fmic
Gestão Electronica:
-MEGASQUIRT 2 V3 EXTRA
-Magnecor silicone 8mm
-FIAT BRAVA COIL
<script src='http://img137.imageshack.us/shareable/?i=dsc00652y.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img291.imageshack.us/shareable/?i=dsc00655wn.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img11.imageshack.us/shareable/?i=dsc00657pl.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img513.imageshack.us/shareable/?i=dsc00659r.jpg' type='text/javascript'></script><noscript>Image</noscript>
bielas h-beam fotjadas testadas para 11000rpm
<script src='http://img600.imageshack.us/shareable/?i=dsc00828b.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img829.imageshack.us/shareable/?i=dsc00831f.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img204.imageshack.us/shareable/?i=dsc00835fv.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img40.imageshack.us/shareable/?i=dsc00834ch.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img214.imageshack.us/shareable/?i=dsc00807s.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img600.imageshack.us/shareable/?i=dsc00809f.jpg' type='text/javascript'></script><noscript>Image</noscript>
reforço rectificado para as bielas nao baterem
<script src='http://img404.imageshack.us/shareable/?i=dsc00812oc.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img684.imageshack.us/shareable/?i=dsc00839y.jpg' type='text/javascript'></script><noscript>Image</noscript>
Para as mas lingues que nao se acreditao no poder dos blocos 1.3
<script src='http://img341.imageshack.us/shareable/?i=dsc00842y.jpg' type='text/javascript'></script><noscript>Image</noscript>
A bela da junta mls
<script src='http://img832.imageshack.us/shareable/?i=dsc00846t.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img826.imageshack.us/shareable/?i=dsc00844w.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img641.imageshack.us/shareable/?i=29072008765.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img42.imageshack.us/shareable/?i=29072008766.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img825.imageshack.us/shareable/?i=dsc00362al.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img835.imageshack.us/shareable/?i=dsc00364z.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img155.imageshack.us/shareable/?i=dsc00366yz.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img80.imageshack.us/shareable/?i=dsc00814tg.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img227.imageshack.us/shareable/?i=dsc00820kw.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img26.imageshack.us/shareable/?i=dsc00933eo.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img641.imageshack.us/shareable/?i=dsc00847dv.jpg' type='text/javascript'></script><noscript>Image</noscript>
knock sensor
<script src='http://img20.imageshack.us/shareable/?i=dsc00853f.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img96.imageshack.us/shareable/?i=dsc00852ys.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img694.imageshack.us/shareable/?i=dsc00851g.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img143.imageshack.us/shareable/?i=dsc00856o.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img835.imageshack.us/shareable/?i=dsc00855me.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img812.imageshack.us/shareable/?i=dsc00095t.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img143.imageshack.us/shareable/?i=dsc00097ul.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img25.imageshack.us/shareable/?i=dsc00859dr.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img822.imageshack.us/shareable/?i=dsc00858a.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img148.imageshack.us/shareable/?i=dsc00956ff.jpg' type='text/javascript'></script><noscript>Image</noscript>
AINDA DIZEM MAL DAS DO MK2 :)
<script src='http://img189.imageshack.us/shareable/?i=dsc00955xh.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img687.imageshack.us/shareable/?i=dsc00957nr.jpg' type='text/javascript'></script><noscript>Image</noscript><script src='http://img189.imageshack.us/shareable/?i=dsc00962js.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img141.imageshack.us/shareable/?i=dsc00967c.jpg' type='text/javascript'></script><noscript>Image</noscript><script src='http://img706.imageshack.us/shareable/?i=dsc00965ug.jpg' type='text/javascript'></script><noscript>Image</noscript>
O VERDADEIRO :)
<script src='http://img193.imageshack.us/shareable/?i=dsc00969my.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img689.imageshack.us/shareable/?i=dsc00972zc.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img832.imageshack.us/shareable/?i=dsc01164m.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img832.imageshack.us/shareable/?i=dsc01170k.jpg' type='text/javascript'></script><noscript>Image</noscript>Image
Uploaded with ImageShack.us
<script src='http://img97.imageshack.us/shareable/?i=dsc01175u.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img703.imageshack.us/shareable/?i=dsc01173c.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://img97.imageshack.us/shareable/?i=dsc01171sn.jpg' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=dsc01754t.jpg&s=714' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=dsc01756hu.jpg&s=84' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=dsc01823ch.jpg&s=24' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=dsc01821xc.jpg&s=225' type='text/javascript'></script><noscript>Image</noscript><script src='http://imageshack.us/shareable/?i=dsc01822uf.jpg&s=231' type='text/javascript'></script><noscript>Image</noscript>
1º TEST VERY VERY SAFE TUNE AND VERY RICH AFR 10.2
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Mon Feb 20, 2012 1:16 pm
oh my that is fast !
just if you want clean up some of the code in your above post and resize the top pics no more than 1000 px width ??
PostPosted: Mon Feb 20, 2012 1:45 pm
Very nice! Thanks for posting up! I love seeing and hearing pissed off big turbo suzukis. T3/t4...im guessin 50 trim?
PostPosted: Fri Apr 20, 2012 3:42 pm
1.3 15 PSI =1BAR / 301HP INSINE TORQUE AND POWER LINE :D
<script src='http://imageshack.us/shareable/?i=dsc00214ow.jpg&s=7' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=dsc00216gc.jpg&s=220' type='text/javascript'></script><noscript>Image</noscript>
PostPosted: Fri Apr 20, 2012 4:28 pm
[quote="jdm_swift"]1.3 15 PSI =1BAR / 301HP INSINE TORQUE AND POWER LINE :D
<script src='http://imageshack.us/shareable/?i=dsc00216gc.jpg&s=220' type='text/javascript'></script><noscript>Image</noscript>[/quote
dyno video http://www.youtube.com/watch?v=gppoxlEy4sY
PostPosted: Fri Apr 20, 2012 6:05 pm
Great pull..makes me optimistic towards my progress..how is boost responce in lower gears..full boost by when..looks to be around 5500..?
PostPosted: Fri Apr 20, 2012 9:13 pm
You're a bad influence! Makes me realize i'm just scratching the surface with my build. Good job man!
Nick Manning
2006 Scion xB (fun-mobile)
PostPosted: Fri Apr 20, 2012 10:17 pm
I love the build - I am wondering a couple things
The intake manifold is not Suzuki, who's is it? I know you must have modified it.
Also the Dyno pull - it looks like 214 hp ATW which is how most people rate theirs.
Never the less great start, maybe a picture of the whole car some time.
90 Swift GT - GT-BBT25 turbo Red - For Sale
99 MX-5 10th AE Saphire Blue
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Sat Apr 21, 2012 4:17 am
<script src='http://img36.imageshack.us/shareable/?i=dsc01841d.jpg&p=tl' type='text/javascript'></script><noscript>Image</noscript>
i think the atw power is not correct.. maybe because de dyno is a MAHA
PostPosted: Sun Apr 22, 2012 5:36 pm
this might be the monalisa of swifts...
tear to my eye..
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Thu Apr 26, 2012 5:43 pm
Do u mind to share part # for the pistons and brand on knock sensor and rods, beautiful build and numbers congrats:-):-):-):-)
89 Suzuki Swift Turbo
03 Infiniti G35 sedan
PostPosted: Sun May 27, 2012 11:00 am
valve spring original :?:
followers lifters original :?:
PostPosted: Mon May 28, 2012 2:23 am
I don't mean to be a party pooper but 214hp at the wheels certainly does not equate to 301bhp at the flywheel, transmission losses for a fwd are more likely to be 18-22%, there is no way you'll lose almost 30%... more realistically you'll have 260-270 bhp which is still quite an acheivement, most of the guys that I know of making 300hp are running 25lbs boost, simply can't do it with such low boost.
Remember a dyno is just a tuning tool, actual numbers aren't accurate, I've seen engines make 250hp on one dyno and 1 week later make 220 on a different dyno.
Take it to the drag strip, do a low 12 sec 1/4 mile and then everyone will believe you are making 300hp 8)
Other than the 'funny' numbers it's a nice looking build :thumbsup:
PostPosted: Wed May 30, 2012 3:02 am
ok i understand.
I put a couple videos, one of these days
PostPosted: Thu Oct 04, 2012 7:47 pm
small video 60km to 210km
http://www.youtube.com/watch?v=rpoYEiGx ... e=youtu.be
PostPosted: Sun Oct 07, 2012 5:52 am
Nice build, congratultions. However I have to agree with Dattman. More like 214hp at wheels and maybe 250hp at engine. Cant see speedo on video! Time to get to a track and test it out. Much safer than the roads :thumbsup:
ImageET 13.138 at 120.2mph
PostPosted: Tue Oct 09, 2012 2:24 pm
214WHP seems about right for 15psi.
Suzuki Gold Master Tech
PostPosted: Tue Oct 09, 2012 4:50 pm
http://www.youtube.com/watch?v=EVvr-ieN ... ure=g-like
http://www.youtube.com/watch?v=BIlVi2hupWM&feature=plcp
http://www.youtube.com/watch?v=G8dJDQUO ... ure=g-like
