It is currently Thu Oct 19, 2017 1:35 am
 Post subject: Turbo questions!
PostPosted: Wed Apr 04, 2012 2:05 pm
Hello everybody.Some turbo advice pls..I am goigng for my first turbo conversation.
First of all, I want to run my turbo setup in small pressure (0.5 bar / 7psi)
-First question
I have a small turbine Garett GT15 and its outpout for intercooler hoses is 50mm, and I want to use 60mm.Can I use 60mm hoses
putting a converter 50 to 60 in turbine's outpout?? Is this turbine small for my setup?
-Second question
What about the CR? Can I use the stock compression ratio or I must drop it? I have in my hand a suzuki baleno 1300. Are that pistons
better for lower compression or to use sto gti's??
-Third question
What about mngement? I have in my hand a Greedy E-manage ECU. Can I solve all management problems with this ECU?
I also have 315cc Supra Injectors and aftermarket Fuel pressure regulator
-Last
What to do in my cylinderhead???
 Post subject: Re: Turbo questions!
PostPosted: Wed Apr 04, 2012 3:29 pm
Sounds good enough...better start reading old posts..
