It is currently Tue Oct 17, 2017 3:08 am
Post new topic Reply to topic  [ 25 posts ]
 Post subject: Large exhaust routing
PostPosted: Tue May 15, 2012 8:11 am
I am looking for pictures suggestions for large exhaust routing. Eg: 2.5-3.0" I have had this done and running for some time but it rattles or bumps to often. The car is lowered and has larger sway bars all of which make the space difficult.
I thought I had it adjusted pretty good ? Then
I added new rear links and this added a new problem plus rough roads .
Thanks
90 Swift GT - GT-BBT25 turbo Red - For Sale
99 MX-5 10th AE Saphire Blue
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Tue May 15, 2012 11:49 pm
I was in the same boat as you... ended up running it out the side. Liked how it looked and it saved a little weight. I put my muffler where the stock resonator was, It was 2.5" from the turbo back.
PostPosted: Wed May 16, 2012 7:11 am
If you're in the position where you need to run large pipe but dont have the room consider oval pipe.
It has the same cross sectional area. I dont remember which companies make it though.
PostPosted: Wed May 16, 2012 7:16 pm
In most cases that can help, but going through the rear suspension of a lowered swift with a large sway bar isn't one of them. I gave up after the 2nd try trying to get no rattles.
PostPosted: Wed May 16, 2012 7:26 pm
Thanks for the suggestions - I spent some time looking again yesterday. I wrapped the sway bar with rubber tape. This helped one spot after some adjusting.
The other thing I found is the rear links I had made may be part of the new rattle. Solid helm joints that are just abit loose. I greased them and noticed a difference.
DSCF3098sm.jpg [250.73 KIB]
Not downloaded yet
2011 Infiniti G37x
2010 Equator White
2000 Solara convert
PostPosted: Wed May 16, 2012 11:24 pm
thats right, i love the look of that. will have to be inspired by this!
PostPosted: Thu May 17, 2012 1:47 am
You'll have to find a compromise that you can live with.
PostPosted: Thu May 17, 2012 3:21 am
Yessssss, that's exactly how I plan on running mine :D
PostPosted: Thu May 24, 2012 8:42 am
You can fit a 2.5 with no problem going the stock route just put an extra hanger near the control arm to make sure you dont get a rattle. 2.5 in will support quite a bit of power more then almost all of the street cars on here will make. 300+ hp
PostPosted: Fri May 25, 2012 2:36 pm
Where you put the muffler? Take pics under neath ima do this hopfully next week
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Fri May 25, 2012 2:39 pm
What type of rims are those that you have on your car??
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Fri May 25, 2012 8:20 pm
You're asking me? (I'm assuming, no other pics in the thread) They are SWT off an Aerio, that had the center machined so they fit the swift hubs.
PostPosted: Fri May 25, 2012 10:27 pm
haha there nice
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Sat May 26, 2012 5:12 am
on min i put the muffler under the middle of the car where the stock resinator was and in the back of the car i put a resinator. you can fit a large muffler under the car with ease. I used a magna flo valve technology muffler and a magna flow resinator. Nice and quite and then in higher boost muffler opens and gets slightly louder. Ill try to get pics monday
PostPosted: Sat May 26, 2012 11:19 am
get a vid too?? i wana hear the beast
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon May 28, 2012 10:58 am
Ill try to get it going today. my fuel pressure regulator popped thursday. It even broke the gauge so i might just have to do the pics at the moment.
PostPosted: Mon May 28, 2012 11:15 am
Car problems... I feel ya on that butbidk whatbisbwrong with my car... It's just shotting oil all over my cat. N I can see under my car
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue May 29, 2012 5:25 am
Ok video is made it makes my car sound like its a rod knock but it is actually the fuel pressure regulator. I just have to figure out how to get it on here today
PostPosted: Tue May 29, 2012 2:53 pm
post it on youtube then take the url n post it on here
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue May 29, 2012 3:22 pm
http://www.youtube.com/watch?v=hBfALmYpcBI
http://www.youtube.com/watch?v=6PAfLwWX4hI
PostPosted: Tue May 29, 2012 8:58 pm
very nice, ilike it also nice eg you got there lol
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Tue May 29, 2012 9:51 pm
my brothers eg its got a h22 in it. Its a turd. He still wont run me even though he claims its like 225whp. That car is such a piece if you saw the cracks in the fram and all that have been welded up. Anyways that dragstrip video was just to show what it sounded like from behind and the other video was just a quick one so you guys would get an idea of how quiet it is in the car. Hope the vid dont make me look to bad i figured a video of the car with problems is enough to get the point across. Thanks Stephen
PostPosted: Tue May 29, 2012 11:15 pm
nice vids. stephennmm . what do you think exhaust would sound like with a cherry bomb and a yoshimura exhaust for a 1.3L bike ?
PostPosted: Wed May 30, 2012 5:22 am
loud and raspy
PostPosted: Thu May 31, 2012 9:43 pm
Most egs are turds lol
2000 metro L"Si":)
2001 suzuki swift
