It is currently Sun Feb 18, 2018 5:53 am
 Post subject: oil feeding
PostPosted: Sat Jun 09, 2012 1:36 pm
One of the only things I can't find much information on is oil feed for turbos. I know that shoving as much oil as possible isn't good. So how much oil should go through it and how is a good way to regulate it? It's a td03L.
GEO MAFIA!
14 ford Mustang v6.
 Post subject: Re: oil feeding
PostPosted: Sat Jun 09, 2012 4:27 pm
a simple solution for limiting oil flow to a turbo is to use an orifice in the supply line.
fill the fitting on the upstream connector of the supply hose with silver solder and drill a small hole through it. at 55 psi (the pressure at which the relief valve on the oil pump operates) a 1/16th to 1/8th inch hole is probably about right to keep from over oiling the turbo.
consider whether the turbo is water cooled or just oil cooled to determine oil flow. i'd only use the orifice on a water cooled turbo housing.
PostPosted: Sat Jun 09, 2012 4:58 pm
It is indeed water cooled.
Does it have to be silver solder? If so could you explain why please?
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Jun 09, 2012 5:54 pm
Senior Member
So the way I did it was to create a grub screw and drill a hole through it with a 40 thou drill.
The grub screw was screwed into the end of the fitting I got to thread into the oil gallery hole on the side of the block.
I created a grub screw by:
tapping a thread into the internal of the fitting
finding a bolt to match the thread
drilling the hole down through the centre of the bolt
filing a slot across the end
cutting the bolt to size
installing into the internal of the oil gallery fitting.
voila
no silver solder
PostPosted: Sat Jun 09, 2012 6:34 pm
From what I've read only ball bearing turbos require a restrictor. I'm not sure about all bb turbos but Garrett bb turbos want between 40-45 pounds of oil pressure. Most restrictor fittings for the Garrett bb turbos are 1mm. Only way to be sure that you're getting the right amount of pressure to the turbo is to tee into the feed line after the restrictor with a oil pressure gauge. That's what I plan to do.
PostPosted: Sat Jun 09, 2012 10:34 pm
Senior Member
1mm = 39.37 thousandths of an inch. I was trying to be kind to those constrained by imperialism...
PostPosted: Sun Jun 10, 2012 12:27 am
Yep, this is the one I bought after reading a dozen posts from google searching and then reading the second FAQ question on Garrett's website here. I will try it with and without with a oil pressure gauge to make sure I'm in that 40-45 pounds zone.
Last edited by 1987TurboSprint on Sun Jun 10, 2012 12:42 am, edited 1 time in total.
PostPosted: Sun Jun 10, 2012 12:41 am
One of the post I came across here. Some places say journal bearings don't need a restrictor, othe places say they want a .060" restrictor. eBay Austraila has a listing for a tdo3 restrictor thats 1.5mm. Again though most places I looked said you should always check to see what your oil pressure feeding the turbo is with and without the restrictor anyways to make sure because pressures change from engine to engine.
PostPosted: Sun Jun 10, 2012 12:44 am
That's just how all the ones I've seen are listed. Everything else on our cars are metric anyways =)
PostPosted: Sun Jun 10, 2012 4:20 pm
Thank you. Good learnage.
87turbosprint in the link to the other forum are they talking about the housing itself being under pressure? And if it leaks under that pressure the housing is no good. I've never heard such a thing but perhaps I read it wrong?
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Jun 10, 2012 4:54 pm
Post #13 is talking about oil supply and restrictors.
PostPosted: Mon Jun 11, 2012 6:01 pm
I've read it a couple times now and I don't think I need a restriction. Because in the housing there is two 1/8th inch holes on either side that I would guess go to journals. But there is another hole in the middle that is about 1/16th inch. And I'm worried that I would be starving the engine for oil. What are some thoughts on this? Also where is a good place to get oil feed from on the 96 g13 8valve engine. I don't see any spots on the head.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Jun 15, 2012 10:52 pm
?? Where is the best place to get oil feed for the turbo?
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Jun 15, 2012 11:54 pm
I'm pretty sure you don't want to feed the turbo from a passage in the head. I'm not sure on the 8v sohc's but on g10's there is an oil passage on the exhaust side of the block right by the oil pump. At least there is on my t3 g10, I think on the non-turbos the passage is just plugged. I'm pretty sure the closer to the oil pump the better. Also on the G10's there is a plugged oil passage right next to the oil pressure sensor, behind the front engine mount.
PostPosted: Fri Jun 15, 2012 11:58 pm
Oh ok. There is a plug on oil pump. I didn't think that would be a good idea because it would starve the rest of the engine.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sat Jun 16, 2012 2:10 am
I used the bung that had the stock oil pressure sensor in it and moved the sensor up to the head.
Nick Manning
2006 Scion xB (fun-mobile)
PostPosted: Sun Aug 05, 2012 1:42 am
Anyone know if the trans coolant lines in an auto radiator would hold up to engine oil temp and pressure. I was thinking i may as well use them if i can rather than no oil cooler. Thanks
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Sun Aug 05, 2012 8:01 am
in general, the passageways in a transmission cooler are smaller and create a huge restriction and an attendant pressure drop if you use them as an oil cooler.
i wouldn't do it. i'd use a dedicated oil cooler heat exchanger with larger bore lines and hoses.
