It is currently Thu Oct 19, 2017 8:38 pm
PostPosted: Wed Jul 11, 2012 9:19 am
HELP!!!!!!
hey guys, watts up I need some help looking for the best set of forged low compression pistons and H-beam or I-beam connecting rods o the market that well not need any modification to install the block is already bored out to 75mm, so am looking for any thing form 8.5-1 or 9.5-1 CR either CP, JE or WISECO
thanks
PostPosted: Thu Jul 12, 2012 4:58 pm
http://www.spoolimports.com/spool-conro ... 3b-conrods
PostPosted: Fri Jul 13, 2012 8:52 am
hey thanks aloy those looking sweet, :twisted: watt about the pistone anything
PostPosted: Sat Jul 14, 2012 12:51 am
slow zuki wrote:
HELP!!!!!!
thanks
For the money I would just use vitara pistons. Remember to take into account how many times the head and block have been resurfaced when calculating the CR.
Alternatively try source +1mm G13BB pistons.
PostPosted: Sat Jul 14, 2012 7:27 am
markimark wrote:
Yup on vitara pistons, unless you want to achieve a specific compression ratio...
Honda guys have been using vitara pistons up around the 500hp mark IIRC
PostPosted: Fri Aug 31, 2012 12:54 pm
I like the spool con rods but I have some questions. Are they going to be 120mm length? I belive the stock rods are 108mm. If I use these rods with vitara pistons what will my quench be? What thickness head gasket should I use to get the proper quench? I am thinking I want to end up about .040". My engine is going in a mosquito helicopter and my plan is 8.5 compression ratio at 8 PSI. I plan on running at 4900 rpm +- 100 rpm only. I will be using a Garrett GT1241 turbo. Engine is from a 1992 geo metro. I am shooting for 85hp max.
PostPosted: Fri Sep 07, 2012 10:32 am
For 8 psi, you don't need to lower compression ratio. Keep the stock 10:1
Stock rods are forged already, and proven to be very strong up to 9K RPM.... so, at 5K RPM there is a huge safety margin. Keep in mind that Gonzalez (sub 10 second swift) is using stock rods, delivering some 350whp @ 35psi... I don't see the point of stronger rods.
Use factory clearances and the engine will last forever at those RPM and boost.
PostPosted: Sat Sep 08, 2012 2:02 am
Thanks for the help.
PostPosted: Sat Sep 08, 2012 4:16 am
:shock: :shock: :shock:
Would love to see the build specs of that engine and I believe he did a 9.91 to be exact :wink:
PostPosted: Fri May 24, 2013 12:30 pm
stock rods?
any difference in rods from before 88 and after?
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
