It is currently Thu Oct 19, 2017 3:10 am
PostPosted: Tue Sep 04, 2012 2:21 pm
like title says i found the motor and ECU and pretty sure the harness. and i want to put it into my car 91 vert.
both cars are 91 fireflys how straight forward is the swap? drop in and go or do some mods?
PostPosted: Tue Sep 04, 2012 5:21 pm
mk2 to mk2 - plug and chug. the only curve is pulling in the coil/ ignitor circuit from the existing chassis wiring's coil connector for switched power.
you might want to change the radiator to one of those chinese fabricated aluminum radiators and a slim line surface mount radiator fan (i like the 12" 1600 cfm type.)
the stock vert radiator's plastic fan shroud gets a little "melty" down by the turbo. i ran my vert's stock radiator for several seasons with the factory turbo3 and it never really gave me any trouble but the aluminum radiator works really well with the engine.
PostPosted: Tue Sep 04, 2012 8:10 pm
"the only curve is pulling in the coil/ ignitor circuit from the existing chassis wiring's coil connector for switched power." can you explain this to me in a bit more detail please thanks.
