It is currently Sat Oct 21, 2017 10:27 pm
PostPosted: Fri Sep 06, 2013 3:28 pm
What's the best type of spark plugs for a gti turbo?
Had a bad misfiring problem under boost then changed the spark plugs and its fixed!
only installed the last spark plugs 2 months ago, so they didn't last long is there a special type of spark plug I should be using?
PostPosted: Sat Sep 07, 2013 9:14 am
I always use(d) the ngk bpr8es and gapped it to 0.7mm with no problems with ~15psi.
Cheap to replace, those expensive iridium plugs ect is just waste of money i think.
PostPosted: Sat Sep 07, 2013 4:34 pm
Man does use 8s wtf :shock:
