It is currently Tue Feb 20, 2018 10:33 pm
 Post subject: turbo pistons and rods?
PostPosted: Fri Sep 13, 2013 11:53 am
For you 3cyl turbo people, what piston and rods are you running? I have a Garret t25 and I'm going .20 over. What is the best, but fairly cheap setup for just daily driving maybe 4-6 pounds with teenage driving? Lol
Does eagle rods and cp pistons make something for our cars?
PostPosted: Fri Sep 13, 2013 1:01 pm
Stock is fine up to 10-15 psi as long as you time and fuel correctly. If you want an upgrade, the most economical is GT/T3 rods, with 98-01 G13 pistons. You might have to skim the top of the piston about .5 mm, but I'd have to measure to be sure.
PostPosted: Fri Sep 13, 2013 1:56 pm
Could I run stoxk even if I bored it? Use oversized rings or something?
PostPosted: Fri Sep 13, 2013 2:41 pm
Stock piston in overbored sleeve? NO. Stock internals will be more than adequate.
GEO MAFIA!
14 ford Mustang v6.
PostPosted: Fri Sep 13, 2013 9:32 pm
So don't bored the cylinders?
PostPosted: Fri Sep 20, 2013 3:24 am
Not if you use stock bore pistons. You can bore the block if you use over sized pistons to fit.
GEO MAFIA!
14 ford Mustang v6.
