It is currently Thu Oct 19, 2017 11:04 pm
PostPosted: Tue Sep 17, 2013 4:29 pm
I'm looking for bearing set for G13B/K engine. This engine will have big Bhp.
I see in USA, you can have Civette 77, ACL, King.. and so on.
Can you tell me which one is the best for std size bearing for turbo use?
I have been told that ACL Aluglide is not as good as Duraglide.
Atchi
PostPosted: Wed Sep 18, 2013 12:35 pm
U can get ACL Race series bearings for the G13.
I have them in my motor but havent run it yet.
I do have them in my Skyline GTR and no troubles with them so far and i dont expext them.
PostPosted: Fri Sep 20, 2013 9:12 am
Is this blue box you used in GT-R or Black box?
Blue box is called Duraglide and black box is Aluglide.
Atchi
PostPosted: Fri Sep 20, 2013 4:19 pm
No, they come in these:
Duraglide and Aluglide are a different type of bearing.
More info right here:
http://www.aclperformance.com.au/SuzukiG13Bearings.htm
PostPosted: Fri Sep 20, 2013 4:55 pm
Saying that one bearing is better than another is many times more about a persons opinion than it is about the quality of the actual bearing....but my choice (opinion) is based on lots of different engines, not only the Suzuki 1.3. I'd like to add that I'd rate the factory Suzuki bearing as good or better than all those listed.
#1 Clevite (if an H series is available that would suit high loads.)
#2 King ... made very similar the factory bearing, and the old Vandervels
#3 ACL ...sorry, I just don't use them if there is any other choice.
All this said, you are assured that the Std size bearings might have higher load carrying ability depending on the manufacturing process. Undersize bearing are often made with a thicker layer of the soft face material (different bearings use different material)
...but a thicker layer of softer material (if that happens to be how your bearing is made) is not a good thing for a high boost turbo engine.
