It is currently Fri Oct 20, 2017 8:47 am
PostPosted: Mon Sep 30, 2013 2:41 pm
http://www.ebay.com/itm/121134848017?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D121134848017%26_rdc%3D1
What do ya think? Is it sized correctly?
Com:A/R:0.60---42.5mm
Turb:A/R0.64---46.2mm
Manifold looks ok, is turbo junk?
I'd like to hear from 1st hand experience, not "I know a guy that knows a guy that got one, it blew up." :)
AKA zukiman79
'89 Swift GTi
'87 Sami 4x4 (Trail only)
check my albums
PostPosted: Mon Sep 30, 2013 5:05 pm
that's a straight up ripped off copy of a turbine tech exhaust manifold. i saw it when they came out and checked it off my list because i have very strong feelings about people ripping off some other guy's handiwork.
they say that imitation is the most sincere form of flattery. in this case it's a poor copy of a great turbo manifold and i wouldn't support the chinese in stealing another guy's business bread and butter.
it's a thin wall stainless steel reproduction that would more than likely fail in short order. exhaust gas temps are pretty high and it would be like a blow torch on those thin walls. the chinese repops of turbos have gotten a lot better so i'd probably have more faith in that than the manifold.
my 2 cents. :wink:
PostPosted: Mon Sep 30, 2013 5:42 pm
Trim is about right? 1: For quick spool, 2: Mid range, 3: peak rpm power? 4: May never spool up?...
AKA zukiman79
'89 Swift GTi
check my albums
PostPosted: Tue Oct 08, 2013 1:53 am
That's an OZMotorsports manifold & from its reviews its a pretty sturdy manifold & the turbo looks to be a Godspeed unit
PostPosted: Thu Oct 10, 2013 9:25 pm
If that is a OZMotorsports stuff , why is it so cheap and coming out of Hong Kong ?
Ken..............
PostPosted: Thu Oct 10, 2013 9:58 pm
better enlarge those pics and look at the tubing wall thickness again.
that will be holed and burnt up in a heart beat.
i think you should buy it, bolt it on an engine, and run it. post lots of pics and give us a review. :wink:
PostPosted: Thu Oct 10, 2013 11:45 pm
I've never ran a turbo on a Swift 1.3L... just wondering if the turbo is close to correct size.
AKA zukiman79
'89 Swift GTi
check my albums
PostPosted: Fri Oct 11, 2013 5:57 am
I'm using this manifold (not the turbo) Been on car for two months had it off about 3 times to repair big cracks where turbo flange meets pipes on mani (lots of weld).
when it arrived the flanges where warped and needed skimming (resufacing) so they were flat with gaskets, engine and turbo.
other than that it works well :lol:
OH and the holes on manifold flange are way bigger than bolts and studs so you need to fiddle when installing to get it straight and lined up with exhaust ports.
PostPosted: Sat Oct 12, 2013 10:22 am
Make love, not moderators
That probably has to do with stainless steel expanding so much. If you use stainless you'll need ALOT of clearance around bolt holes so it doesn't shear them off when it expands.
PostPosted: Fri Oct 18, 2013 9:07 pm
The mad quebecer
The mad quebecer
Lol, I'm amazed how good those guys are in the conterfeit business. That manifold is 100% carbon copy of the design I was making back in 2002 before starting the twin scroll trend. :D
PostPosted: Wed Oct 30, 2013 9:45 am
So.... what about the size and trim of turbo... would it work on a little 1.3L ? :huh:
AKA zukiman79
'89 Swift GTi
check my albums
