It is currently Tue Oct 17, 2017 10:36 am
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Oct 30, 2014 5:08 am
Hi,i' m from Italy.
here are my project
g13 engine rebored 74,5
CPS pistons
IHI turbo
H beam rods
EFI menagement
...and more
pics soon
ONLY TURBO CARS AT OUR HOME
PostPosted: Thu Oct 30, 2014 2:01 pm
:lol:
File comment: pistons
PostPosted: Thu Oct 30, 2014 2:07 pm
peened shoting head
File comment: the head
PostPosted: Thu Oct 30, 2014 10:03 pm
Pistons and head looking good! What kind of valves do you plan on using?
dave
93' Suzuki Swift Gt Turbo
PostPosted: Fri Oct 31, 2014 7:11 am
I'll use stock valves .....oversized i think in future step
PostPosted: Sat Nov 01, 2014 4:54 pm
squirters installed
:thumb2:
PostPosted: Sun Nov 02, 2014 6:01 pm
Looks good. Any more info on the pistons?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Mon Nov 03, 2014 8:30 am
Forged pistons CR 9:1 C.P.S. Italy
PostPosted: Mon Nov 03, 2014 6:07 pm
Thank you.
If you don't mind me asking; how much does a set of those cost?
edit: wow, just took a look on their site. They have some really nice high compression pistons for the gti. They even have pistons for the vitara, swift sport and samurai 8v engines.
http://www.pistonispeciali.com/EN/cars.htm#.VFg2pBaPMfk
2003-EVO7 GT-A
PostPosted: Sun Nov 09, 2014 9:57 am
cost for a set is 740 euro,but for me Wiseco looks better then CPS
PostPosted: Sun Nov 09, 2014 11:55 am
valves fitted. Chamber volume with spark 30,5 ml
PostPosted: Tue Nov 18, 2014 8:05 am
:thumb2:
File comment: rods & main race bearings
PostPosted: Tue Nov 18, 2014 6:14 pm
Ready for fit
PostPosted: Tue Nov 18, 2014 6:25 pm
pistons are fitted,now it's time to upside down the block and go on with the bottom
PostPosted: Tue Nov 18, 2014 6:31 pm
an issue occurred, bolts knock under bracket
PostPosted: Tue Nov 18, 2014 6:40 pm
i've milled the bracket ,best solution and easy work ...not fine to see but solved .
Tomorrow i will finishing bracket by sandblasting
PostPosted: Tue Nov 18, 2014 9:45 pm
what deck clearance do you have? Piston to deck surface.
Cars and Harleys
PostPosted: Tue Nov 18, 2014 10:03 pm
great build
PostPosted: Wed Nov 19, 2014 3:52 pm
Deck clearance is 0 mm
PostPosted: Tue Nov 25, 2014 4:21 pm
head mount & check
PostPosted: Tue Nov 25, 2014 4:32 pm
i realise that i've two kind of cams : above is inner grooved and under is monolithic... someone know why?
PostPosted: Wed Nov 26, 2014 7:52 am
PostPosted: Fri Dec 12, 2014 4:35 pm
Can you post the specifications on the pistons..........
89 Suzuki Swift Turbo
03 Infiniti G35 sedan
PostPosted: Sat Dec 13, 2014 8:49 am
I sometimes wonder if that bracket / brace is really necessary.
2003-EVO7 GT-A
PostPosted: Sat Dec 13, 2014 8:53 am
The inner grooved one (hollow one) is from an mk2 gti. ('89-'91)
The monolithic one (solid one) is from an mk3 gti. ('92-'99)
Stock specs are the same for mk2 and mk3.
2003-EVO7 GT-A
