It is currently Thu Oct 19, 2017 9:33 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Dec 13, 2014 6:26 pm
thanks for your precision...i choose for mk3 cams,they are stronger!
i think bracket is important to keep main caps togheter and for vibrations too
ONLY TURBO CARS AT OUR HOME
PostPosted: Sat Dec 13, 2014 6:32 pm
injectors fitted
PostPosted: Sat Dec 13, 2014 6:36 pm
Turboraz wrote:
Can you post the specifications on the pistons..........
rebored to 74.5 mm ,dished (-4 cc) and forged by C.P.S
PostPosted: Sun Dec 14, 2014 6:59 am
File comment: top view
PostPosted: Sun Dec 14, 2014 7:05 am
[img][/img]
PostPosted: Mon Dec 15, 2014 6:30 pm
Make love, not moderators
Looks great! What injectors are you using? I am in the market for new ones myself but would like to get something better then the stock ones.
PostPosted: Tue Dec 16, 2014 5:35 am
i used saab turbo ones
PostPosted: Tue Dec 16, 2014 6:17 pm
Alex, time is running fast and I can't wait anymore to see your beast on the road. I Konw Alex and was on his first turbo swift... it was breathtaking. We had a casual drag verse a honda S2000. The driver was astonished, For sure he didn't believe the easy way we were far away in a blink. I can't imagine what Alex will extract from his top hat. As he usually say: "stay tuned".
PostPosted: Wed Dec 17, 2014 3:34 pm
gruppob wrote:
injectors fitted
Oh how I hate those 2 stock bolts that holds the fuel rail into place. :puke: :lol:
Also the stock ones for the dizzy are long gone on my engines.
I just used normal 12mm ones.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Dec 18, 2014 4:39 am
Remember that time, full throttle and honda left back....next time we'll beat more powerfull car like Porsche !!! ;-D
PostPosted: Sun Dec 28, 2014 11:22 am
time to gear rebuild,changing synchro,ball bearing and oil seals...and not last.... a big case housing cleaning. Next step i will change 5th gear from 1.3L GS gearbox, i need a longer 5th ratio, because i've 220Km/h @ 7500 rpm :oops:
PostPosted: Tue Jan 06, 2015 1:07 pm
now i've reinforced engine mounts, it's important for shifting gears accuracy and make engine more stable
PostPosted: Tue Jan 06, 2015 1:16 pm
i used Sikaflex 252,it has 50 SHORE stiffness coefficient. i think is good for this
PostPosted: Wed Jan 07, 2015 4:27 pm
Great project, keep it up!
I reinforced my engine mounts exactly the same, but haven't driven it yet :)
PostPosted: Wed Jan 07, 2015 6:22 pm
i will come back on the street next month.... :lol: .... your GTi is turbo or normal?
PostPosted: Thu Jan 22, 2015 1:57 pm
difference between 5th gear GTI (31 x 27 under) , 1.3 GS ( 33 x 25 above).
with Gs gears i increase max speed and decrease rpm, right choice for long run and better fuel economy.
here calculation gears Link:
http://www.volkshouse.com/volkshouse/utility/cambio.html :idea:
PostPosted: Thu Jan 22, 2015 4:03 pm
Sorry for the late reply... It's still N/A for now, I want to make it roadlegal and get it approved first.
What RPM will it run @ 120km/h with the new GS gears and what did they cost you? With the original gears it does like 4000RPM @ 120km/h :o
PostPosted: Fri Jan 23, 2015 1:24 am
Beautiful work!!
1995 Suzuki Swift 1.3 16v GTimk3 74kw
2005 Suzuki Ignis 1.5 16v GS VVT 73kw 4x4
2002 Lada Niva 1.7i+lpg 4x4
Last edited by PocketRocket87 on Sat Feb 28, 2015 9:51 am, edited 1 time in total.
PostPosted: Fri Jan 23, 2015 7:56 pm
@ 120 kmh , it s 3400 rpm, price for both 180€
PostPosted: Sat Jan 24, 2015 2:39 pm
3400RPM sounds great! Thanks for the partnumbers :D
PostPosted: Sun Feb 01, 2015 6:07 pm
:alien:
PostPosted: Wed Feb 04, 2015 2:36 pm
READY TO FIT, i'm excited!!!
PostPosted: Fri Feb 06, 2015 9:40 am
engine fitted but there is an issue.... when gears run i hear noise from gearbox like bearings, but they're new.... :huh:
PostPosted: Wed Feb 11, 2015 5:52 pm
8)
PostPosted: Tue Feb 17, 2015 3:33 pm
Looks good! Did you solve the noise issue?
