It is currently Thu Oct 19, 2017 12:06 pm
PostPosted: Mon Mar 16, 2015 8:32 pm
As per title, would this be a good turbo for the GT?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Wed Mar 18, 2015 11:58 am
Buy a GT2560R... Great turbo for our little engines
PostPosted: Sun Mar 22, 2015 12:10 pm
https://www.rbracing-rsr.com/calcboost.html
Go there. Punch . in your engine info and see what the results are. take the boost psi and convert to pressure ratio then find some turbo maps and see where that takes you. For my 1.0l it require a gt2860. So it all depends on what you want to achieve For power
Edit. I should say I'm going with a gt25/28 hybird in my case
Last edited by redneck racing on Sun Mar 22, 2015 12:30 pm, edited 1 time in total.
PostPosted: Sun Mar 22, 2015 12:28 pm
So say you want 150 HP with a 7000 rpm redline. The engine will require 18.69 lb/min of air at 12.1 psi. That converts to 1.8 pressure ratio at sea level. So looking at a turbo map find 19 lb/min at the bottom and 1.8 p/r on the side and see where it sits.
As you will see in the pic for those specs on a gt25 turbo it puts you right smack dab in the center of the most efficient part which means it would be perfect for that set up.
PostPosted: Tue Mar 24, 2015 10:47 am
Thank you redneck. That helped a lot! :thumbsup:
2003-EVO7 GT-A
