It is currently Sat Oct 21, 2017 7:05 pm
 Post subject: Boost a pump
PostPosted: Sun Sep 13, 2015 3:54 pm
I know big boost utilized one with the stock fuel system for his dyno runs, but has anyone else used one reliably on a daily driver. I am wondering if this could help the stock fuel system keep up above 7psi and maybe upgraded injectors to help with spray pattern.
This is for a 1987 sprint turbo 226/395 cam garrett gt1544 turbo and 75mm vitara pistons
 Post subject: Re: Boost a pump
PostPosted: Fri Nov 13, 2015 8:04 pm
well, it depends on fuel tank. the 87 turbo sprint is a bit of an oddball. ASSUMING they used the same fuel pump as the 90+ geo metro, you SHOULD be able to drop in the bigger fuel pump from the 1.3gti, i think.
id worry more about the stock MAF if you upgrading boost.
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
PostPosted: Fri Nov 13, 2015 8:09 pm
Stock pump (same as GT) should do the job fine on it's own.
Users browsing this forum: Majestic-12 [Bot] and 3 guests
